November 21, 2026, 05:04:43 AM
Dongles on Android
Started by IanH, October 04, 2014, 10:38:42 AM
Doing a search for RTL2832U info and I stumbled across this:
https://play.google.com/store/apps/details?id=marto.rtl_tcp_andro&hl=en
So the interface is working - just need software cross-compiling. And looks like someone already has:
https://play.google.com/store/apps/details?id=com.wilsonae.android.usbserial&hl=en
LX-LGN
Ian,
Have you tried this yet?
I have a spare DVB-T Dongle at home I bought wondered if using that plus 'ADS-B on USB SDR RTL' and OTG cable is worth a go.
EGTE24
I've tried it - in fact, I have it running now - on an Arcos 80 G9 tablet.
It works well in 'text view', outputting in a format similar to that from dump1090, however in 'map view' it's rather unstable.
I would say it's worth paying the 91 pence for though, if only to encourage the developer to progress with it, as it has potential.
Terry
LX-LGN
#3
Which OTG cable did you go for? I would want one that charges the phone at the same time.
I have send the developer an email asking if there is a logging facility or whether that cane be made on it i.e. tap a place to record the reg/Hex in a log/txt/word file.
LX-LGN
#5
Thanks Terry,
I am looking on amazon for one.
When you're using the dongle does it drain power much?
EGTE24
Quote from: LX-LGN on October 29, 2014, 02:17:17 PM
Not significantly on the Arcos, but having said that, I've only used it for relatively short periods - 10 to 15 minutes at a time.
Terry
LX-LGN
Thanks Terry.
I have ordered the cable and downloaded the free version and will upgrade if it all works.
Looks like something else to try  ;D
Thanks for the feedback.
LX-LGN
Hi all,
Cable turned tup today.
Connected to a DVB-t dongle and the android software and bingo. It works with the test app. Will d/l the.91p version next
It gives a map and a data list but in hex only. Still not bad. If the weather improves I can give It a full once over
Looks like the free version of that isn't available any more to try - pity since I want to check it works on my tablet.
Found another free item which runs for 2000 packets before stopping - at least it showed it worked on my Samsung Galaxy Tab 8.3.
https://play.google.com/store/apps/details?id=bs.Avare.ADSB&hl=en_GB
Paid version is £1-56 - not tempted yet.
https://play.google.com/store/apps/details?id=bs.Avare.ADSB.Pro&hl=en_GB
And I reckon that these apps on Android will have limited appeal given the arrival of full Win8.1 on 7 and 8 inch tablets for £80 and £100 so you can run the apps you already know and love  ;D.
Limited RAM and disk space but depends what you want them for.
http://www.uk.insight.com/en-gb/productinfo/tablets-pdas-and-smartphones/0003814100-00000001
Apparently just the beginning of a wave of "cheap" Win8.1 tablets.
Quote from: LX-LGN on November 03, 2014, 01:17:17 PM
Cable turned up today.
Is the cable one that will charge the phone as well as run the dongle as I'm looking for one to use with my tablet.
I don't know and even after a quick look on the web, I'm none the wiser.
The OTG cable has some simple wiring changes compared to a standard cable but whether it affects the charging capability I don't know.
shakysen
I have a Belkin charges Kindles' ipod. Scanners.IPhone at 2amps
