April 22, 2026, 04:29:02 PM
PlanePlotter 6.4.9.5 Released
Started by Triple7, May 01, 2020, 03:33:46 PM
From Bev
PlanePlotter version 6.4.9.5 is on the web site now.
---Usual boilerplate---
New in version 6.4.9.5
Faster SMU operation
This update will be welcomed by our dedicated Sector Master Users (SMUs) as it significantly reduces the processing load of an SMU cycle.  Previously, SMUs that were well supplied with Ground Stations in their area and which enjoyed a high density of traffic, could be occupied for many seconds during each SMU cycle.  Now the processing time is reduced to a second or so even for the busiest and most productive SMUs.  Any SMUs (or potential SMUs) who were inconvenienced by the processing load of earlier versions, are urged to install this latest release.  Many thanks to John Locker for identifying this infelicity and for patiently testing countless versions that eventually resolved it.
DF-18 report display (changed in server)
A bug in earlier server scripts meant that DF-18 report types were only downloaded from the sharing server if all the download options were ticked.  This bug is now corrected so that DF-18 report types are downloaded and displayed as long as both Mode-S reports and the DF-18 option are ticked in Options..Sharing..Setup sharing.
Mode C graph extension
The graph that is displayed when the "View..Mode C altitude window" is selected, now extends to flight level 800 when clicking on the graph. Previous versions expanded the graph to FL600.  This is in the (forlorn?) hope that the occasional passing U2 might show an interesting trace.
TCP socket closes
Previous versions left TCP sockets defined in "Options..I/O settings" open when processing stopped.  If the selected TCP port was then changed and processing restarted, both ports were sometimes seen to be active.  This version seeks to resolve that anomaly.
Enjoy!
Bev
COAA
