November 10, 2026, 10:03:54 PM
Flight Aware Pro Stick Plus, Feeding Basestation (2020)
Started by KeithB, June 02, 2020, 09:16:32 AM
Thanks Tim.
That was my thought but as I haven't done this myself, I decided to let someone with more knowledge respond.
All I'll add is to avoid installing any default USB drivers for the receiver.
Nigel
Ken: there is a small error in your batch file. There should be a space between basestation.sqb and --msg 30003, although you don't really need the --msg command. you may also want to remove --freq-correction 62
Keith: your simplified batch file is fine.
In both cases the issue seems to be linked to reading data from the Prostick and needing the Zadig drivers installed as Tim suggests
Hopefully that will get you both up and running
Nigel
KeithB
Tim, Nigel and Anmer,
Now all working..
Thank you very much....
KeithB
Hello again all,
I spoke too soon.. After being away from the laptop for a few days, I came back to it and the
shortcut for Modesdeco2 had disappeared.. Couldn't find it, tried the whole process again and
now getting an error message :
'modesdeco2.exe' is not recognized as an internal or external command,
operable program or batch file.
Press any key to continue . . .
Could someone please put me right... It did work last week, I seem to have done
something wrong......... HELP..... Please
Shortcuts don't normally disappear on their own.  Did anything else change?  Or has it just moved?  Try rearranging them.
Have you checked that Modesdeco2.exe is in the folder location that you're now using?
KeithB
Thank you again Anmer,
I worked through the files, nailed the shortcut to the desktop and it's working again....
Reassurance is what I needed........
Thank you........
