August 26, 2026, 09:14:14 PM
ADS-B Antenna Splitter
Started by BVE16, June 15, 2020, 08:57:16 AM
G4UMW
Rob/G4UMW
Graham Bell
Bless you !!  ???
Regards.. G.B.
G4UMW
Rob/G4UMW
Faramir
Quote from: G4UMW on October 26, 2020, 05:57:42 PM
True, but BNCs and N-types are easier to fit to thicker coax.
No easier than SMA, SSB has easy to use connectors for all kinds of coax. :)
I find thicker coax, 10mm and 15mm diameter, can place a strain on the receiver's connector and has been known to damage it.
This can be avoided if the thicker coax is first connected to a splitter and thin, short "fly leads" from the splitter. to the receiver(s).
Faramir
Absolutely true! On my RTL-SDR dongles it is less of a problem but on any desktop receiver it's important to make sure the coax doesn't put any strain on the connector.
HL7222
https://www.ebay.co.uk/itm/Mini-Circuits-ZN2PD-20-Coaxial-Power-Splitter-Combiner-2-Way-750-2000MHz-5W-RF/141009323202?hash=item20d4cf84c2:g:IKEAAOSwWnFV8oDj
HI,
This is the link that Anmer quoted a while back... but it still seems to be live. I just wanted to check that this splitter will still work for ADSB and Civil/Mil Airbands??
Quote from: HL7222 on April 16, 2021, 02:20:29 PM
Looks like the seller has more than one of these - 22 available/16 sold.
Mine was a Mini-Circuits ZB4PD1-2000 Power Splitter/Combiner, 2000 MHz.
The one listed is a different model but appears to cover the 1090MHz frequency.  But airband at 108-137 MHz isn't covered.  It starts at 750 MHz.
Nigel
I can recommend this one from ADSB (1090 MHz): https://www.ebay.co.uk/itm/MINI-CIRCUITS-ZESC-2-11-POWER-SPLITTER-COMBINER-2-WAY-BULK-DISCOUNT/264710279227
and something like this works well for airband: https://www.ebay.co.uk/itm/BNC-Male-to-2x-BNC-Female-Splitter-Y-Piece-Adaptor-for-TV-Connector-CCTV-Camera/282706277648
Ensure the connections meet your needs i.e. SMA for 1090MHz, and BNC for airband
Nigel
HL7222
Thanks chaps.
I need SMA for Airband too, as it will be to feed an SDR
I will look at the suggestions, thanks
HL7222
Quote from: Nigel on April 16, 2021, 04:45:29 PM
Nigel
\Hi
I have ordered the ADSB splitter... but still looking for an SMA splitter for the airband.
I am also looking for a good supplier of pig-tail leads to run off the splitter to the receivers.
ADSB will be going to Flightaware Blue Stick and SBS-3.
Airband will be going to SBS-3 and Airspy Mini
Nigel
The splitter I suggested for ADSB (https://www.ebay.co.uk/itm/MINI-CIRCUITS-ZESC-2-11-POWER-SPLITTER-COMBINER-2-WAY-BULK-DISCOUNT/264710279227) should also work for airband frequencies as the wavelength range is 10-2000 MHz, although I have not tried it for this.
I obtained pigtails from the following source on ebay:  https://www.ebay.co.uk/itm/SMA-male-to-SMA-male-pigtail-patch-lead-15cm-RG-316/254180455597
They are male to male connections which is fine for use with the splitter and FA Prostick/SBS-3 inputs
HL7222
Thanks Nigel,
I shall try the one I just ordered on both set ups once its arrives and maybe add a second. Splitting the airband isnt so important, so no crazy rush.
I will get the pigtails ordered up off that link, thanks.
Paul
