September 06, 2026, 06:10:56 AM
Populated SQB file
Started by s92driver, August 16, 2020, 11:25:48 AM
s92driver
The latest SQB file and associated "Silhouettes" will be posted by Anmer tomorrow.  This latest version introduces a couple of subtle changes.
Firstly it will remove the non-standard ICAO codes that have been present up to now, for example all Canadair Challengers will show CL60 whereas previously you would also find CL61, CL64 and CL65.
There's also a simplification of ATR42 and ATR72 images and associated OperatorFlagCodes.  Previously you may have seen a FlagCode containing AT72, AT73, AT75, AT76 whereas now they will have an image and OperatorFlagCode of AT7x.  Similarly MD81, MD82, MD83 & MD88 are now MD8x.  Note that this change does not affect the ICAO code, just the OperatorFlagCode field.  This is simply to reduce the number of images supplied, as the more images that are loaded the slower the boot up is.  Some users have reported issues when the total number of images being loaded is in excess of 8000.
I would recommend anyone that uses the SQB and associated images to download both every month.  I do update images without posting the updates in the Gallery, however more importantly every month I do remove images that are no longer used as well as rename images when aircraft change registrations (eg bizjets).
Steve
s92driver
The lastest update will probably be available tomorrow.  A quick message to highlight that there's been a large "clean out" of special OperatorFlags, so the overall number of images will probably drop in the Zip file compared to last month.
Steve
aviaction
Thanks you for maintaining an SQB file. Just uploaded and it covers almost everything. If a donation continues support this, then I am in.
s92driver
It's been a year since my last message - yikes!  The updated SQB and associated OperatorFlags zip files have been updated and posted on a monthly basis since I started publishing the SQB in 2020.  I've no intentions of changing that.
The SQB and OperatorFlags can be used with VRS, Basestation, or any other software that uses the SQB format as a source database.
This message is to highlight a few headlines:
The database now contains more that 500,000 hex codes, where applicable associated with current registrations only.
There are more than 2500 miscodes.
There are more than 7250 "ground based" hex codes, usually with details of where they are located.
If the SQB is used with the OperatorFlags zip file, then each code received will result in the applicable image for that aircraft being displayed.  No more constant manual adjustments of the SQB is needed!
I have also been updating a number of SQB files for various users every month.  This has been happening without issue for at least 3 years.  This has the benefit of keeping your existing SQB in use, maintaining all of the receiver history.  If you'd like to give this a try or have any questions leave a message here or send me a dm.
Steve
webmonkeyuk
id just like to express my heartfelt thanks and massive appreciation for this file and also the outlines. I had been suffering from lots of blank entries with my reg codes and it was looking awful and it was also affecting my PP display too.
downloaded your up to date sqb file and outlines to go with it and it looks absolutely amazing now so much better and up to date.
again many thanks for keeping the up dates going
s92driver
Quote from: webmonkeyuk on June 25, 2025, 12:18:06 PMid just like to express my heartfelt thanks and massive appreciation for this file and also the outlines. I had been suffering from lots of blank entries with my reg codes and it was looking awful and it was also affecting my PP display too.
Thanks for the feedback.  I'm glad you find it useful.
Steve
Radu
Good day,
Can someone tell me where I can find an Sqb. file populated with  generic Silhouettes Black ones, instead of airline logos or airline silhouettes .  Thank you very much !
An sqb file isn't populated with any logos or silhouettes.  What it has is a populated OperatorFlagCode field.  The sqb file that's available here is produced by S92driver who uses the OperatorFlagCodes that match his logos/silhouettes.
The solution is to use an SQL editor to change the OperatorFlagCode field to use codes that match the logos/silhouettes you prefer.
