November 10, 2026, 08:55:48 PM
QUERY Re: feeding more than one site
Started by Andos, January 14, 2021, 01:02:37 AM
Andos
Hi Nigel, Anmer, Ian,
                                 Is the problem I am experiencing possibly because I have dump1090-mutability installed on my FlightAware Stick Pro Plus?
                             Andos.
Andos.
Quote from: Andos on January 15, 2021, 02:22:25 PM
Just to clarify again, you do not have anything installed on your Pro Stick.  Dump1090 is installed on the RPi.
The RPi needs an operating system and message decoding software.  Plus code to share the data with a flight tracking service such as FlightAware.
The FlightAware PiAware application is a combined operating system, decoder and data feeder.  But it only feeds data to FlightAware.
If the data is to be shared with other flight tracking services, the RPi install needs editing to add the additional feeds and avoid conflicts.
Nigel posted:
QuoteYes. I installed dump1090-fa first and made sure that was up and running, then installed all the other feeders (FA Piaware; PlaneFinder; FR24; Radarbox; 360Radar; ADSBx) + PlanePlotter separately following the feeder installation instructions for each
He also added a link to a post by abcd567 (which is also posted on this forum - https://radarspotting.com/forum/index.php?topic=9623.msg40971#msg40971)
https://forum.radarbox24.com/index.php?topic=10201.0
You mention running dump1090-mutability.  Not dump1090-fa.
Maybe revisit Nigel's post and abcd567's instructions?
Nigel
Hi Andos
You need to follow Option 1 of the post by abcd567. That is for dump1090-mutability
Nigel
Andos
Ok Nigel,
              I shall have a look and I shall let you know how I get on.
          Andos.
Andos.
Andos
Hi Nigel/ All,
                    I have had a look at abcd567's instructions.  Am I right in assuming that I would have to format RPi's SD card and start again to perform his instructions?  I think I am getting a little confused.  He mentions a "Stretch" version.   I am currently using Debian.
                     I plan to undertake this project tomorrow so I am trying to prepare and understand everthing beforehand.
            Andos.
Andos.
"stretch" is a previous version of Debian. Current version is "buster".
All named after characters in Toy Story.
https://en.wikipedia.org/wiki/Debian_version_history
Andos
Hi Nigel/ All,
                   I have now discovered that my installed version onto my SD card is dump1090-fa and my Debian version is "jessie".  I have re-tried the "sudo bash -c "$(wget -O - http://apt.rb24.com/inst_rbfeeder.sh)" "command as in Option 2 from abcd567's instructions, but after the process completes its checking of the existing files and directories, I still keep receiving the following response  (-the asterisks are used to mask my ID details):
Reading package lists... Done
Building dependency tree
Reading state information... Done
dirmngr is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 120 not upgraded.
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.oqPVBTRoMG --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyring /etc/apt/trusted.gpg.d/flightaware-archive-keyring.gpg --keyserver hkp://p80.pool.sks-keyservers.net:80 --recv-keys ********
gpg: requesting key ******** from hkp server p80.pool.sks-keyservers.net
gpg: key ********: "AirNav Systems <jceara@airnavsystems.com>" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
Don't know how to install for a distribution named
    It is not installing the software.  Does anyone know why this keeps occurring?  Obviously, I cannot proceed any further until this has been achieved.
I have also just noticed that just after the connection process, it says Line 17 cannot be found ( see below):
Connecting to apt.rb24.com (apt.rb24.com)|104.26.4.230|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2406 (2.3K) [text/x-sh]
Saving to: 'STDOUT'
-                   100%[=====================>]   2.35K  --.-KB/s   in 0s
2021-01-18 12:58:29 (41.1 MB/s) - written to stdout [2406/2406]
bash: line 17: lsb_release: command not found
    I have added the processes in the hope that someone might recognise what might be causing this problem.
                     Andos.
Andos.
Nigel
Hi Andos
Sorry I've no idea what is happening with your installation. It might be worth posting the details of your issue on the AirNav Forum ( https://forum.radarbox.com/index.php?board=4.0) and/or sending an email to AirNav Support (support@airnavsystems.com)
Nigel
Oblivian
The keys are not IDs. But hash from the remote end to verify it. Nothing identifiable to you
It's part of the script
# Import our key to apt-key
apt-key adv --keyserver hkp://p80.pool.sks-keyservers.net:80 --recv-keys 1D043681
And if it is, something else has been setup wrong. Would not expect it to ever say your name or anything particular to you
I expect half the packages no longer have Jessie equivalents. Per the earlier link, that is now 3 versions old. And many file stores do not know how to handle when the name Jessie is presented.
You might need to upgrade the OS
https://www.raspberrypi.org/documentation/raspbian/updating.md
As in the script, you can see it can't find jessie. Only Stretch and Buster
Create a new debian repository source file
case "$VERS" in
    stretch)
        echo 'deb https://apt.rb24.com/ stretch main' > /etc/apt/sources.list.d/rb24.list
     buster)
        echo 'deb https://apt.rb24.com/ buster main' > /etc/apt/sources.list.d/rb24.list
        echo "Don't know how to install for a distribution named $DIST
And that's the message you see as it doesn't match expected
