September 21, 2026, 08:32:21 PM
IanH654
Thanks Anmer,
Hopefully the other person on the forum had similar luck with a re-installation.
IanH654
Quote from: IanH654 on August 11, 2023, 12:40:10 PMThanks Anmer,
There are a few of us here who might think he wouldn't  ;)
Kev_Strickson
hey guys my sbs-populate has  stopped running and i get the error
I have un installed it and  when I attempt to install it again I get
Application cannot be started. Contact application vendor.
The programs  starts to install and looks like its scanning then the error pops up
I am running Windows 10 64 bit 22H2 (and it worked ok up to the last windows update)
Anybody any idea please
I use it for updating my data base
The details of the failure are below
Many thanks
Kev S
PLATFORM VERSION INFO
                Windows                                             : 10.0.19045.0 (Win32NT)
                Common Language Runtime        : 4.0.30319.42000
                System.Deployment.dll                  : 4.8.9176.0 built by: NET481REL1LAST_B
                clr.dll                                     : 4.8.9167.0 built by: NET481REL1LAST_B
                dfdll.dll                                 : 4.8.9176.0 built by: NET481REL1LAST_B
                dfshim.dll                                            : 10.0.19041.30000 (WinBuild.160101.0800)
SOURCES
                Deployment url                                 : file:///C:/Users/Kevin/Desktop/GAS%20Populator%2064bit%20Install%20&%20Zip/SBSPopulateDB.application
                Application url                                   : file:///C:/Users/Kevin/Desktop/GAS%20Populator%2064bit%20Install%20&%20Zip/SBSPopulateDB_1_64_0_13/SBSPopulateDB.exe.manifest
IDENTITIES
                Deployment Identity                       : SBSPopulateDB.application, Version=1.64.0.13, Culture=neutral, PublicKeyToken=1e579edb8ae38d8a, processorArchitecture=msil
                Application Identity                         : SBSPopulateDB.exe, Version=1.64.0.13, Culture=neutral, PublicKeyToken=1e579edb8ae38d8a, processorArchitecture=msil, type=win32
APPLICATION SUMMARY
                * Installable application.
ERROR SUMMARY
                Below is a summary of the errors, details of these errors are listed later in the log.
                * An exception occurred while determining trust. Following failure messages were detected:
                                + Value does not fall within the expected range.
                * Activation of C:\Users\Kevin\Desktop\GAS Populator 64bit Install & Zip\SBSPopulateDB.application resulted in exception. Following failure messages were detected:
COMPONENT STORE TRANSACTION FAILURE SUMMARY
                No transaction error was detected.
WARNINGS
                There were no warnings during this operation.
OPERATION PROGRESS STATUS
                * [11/08/2023 16:55:51] : Activation of C:\Users\Kevin\Desktop\GAS Populator 64bit Install & Zip\SBSPopulateDB.application has started.
                * [11/08/2023 16:55:51] : Processing of deployment manifest has successfully completed.
                * [11/08/2023 16:55:51] : Installation of the application has started.
                * [11/08/2023 16:55:51] : Processing of application manifest has successfully completed.
                * [11/08/2023 16:55:52] : Found compatible runtime version 2.0.50727.
                * [11/08/2023 16:55:52] : Detecting dependent assembly Sentinel.v3.5Client, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=msil using Sentinel.v3.5Client, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=msil.
                * [11/08/2023 16:55:52] : Detecting dependent assembly System.Data.Entity, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil using System.Data.Entity, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil.
ERROR DETAILS
                Following errors were detected during this operation.
                * [11/08/2023 16:55:52] System.ArgumentException
                                - Value does not fall within the expected range.
                                - Source: mscorlib
                                - Stack trace:
                                                at System.Deployment.Internal.Isolation.IDefinitionAppId.EnumAppPath()
                                                at System.ActivationContext.CreateFromNameAndManifests(ApplicationIdentity applicationIdentity, String[] manifestPaths)
                                                at System.Deployment.Application.ActivationDescription.ToActivationContext()
                                                at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
                                                at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
                                                at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl, Uri& deploymentUri)
                                                at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivationWithRetry(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
--- End of stack trace from previous location where exception was thrown ---
                                                at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
                                                at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
                                - Source: mscorlib
                                - Stack trace:
COMPONENT STORE TRANSACTION DETAILS
                No transaction information is available.
Did you uninstall SBS-1 Populate before trying a fresh install?
The most recent Windows update is Pending on my PC.  I'll see what gives when I run it  :-\
Latest Windows Update installed and SBS-1 Populate working as normal.
No need to do a fresh install.
Windows 10 64 bit:
August 8, 2023—KB5029244 (OS Builds 19044.3324 and 19045.3324)
August 8, 2023-KB5029649 Cumulative Update for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2
Successfully installed on ‎11/‎08/‎2023
Kev_Strickson
same updates as mine.
Do you have a  link  for the  64 bit GAS populator so i will try a fresh version
kev
I've uploaded three versions of SBS-1 Populate:
1.32.0.13 GAS
1.64.0.13 GAS
1.64.0.13 dutchradar.nl
I don't know which version you had installed.  Mine is the dutchradar version.
When do you get the error?  When you load SBS-1 Populate or when you use it?  And how do you launch it?
Kev_Strickson
No joy on those  exactly the same failure message.
This is what i do
1) download wib zipped file
2) extract to a seperate  file
3) Run set up (either as administrator or not)
4) it  pops up showing its starting to install
5) I then get the error I mentioned
Any ideas ?
Kev S
Kev_Strickson
Cheers for the ongoing help
Found the folders in app data removed them all rebooted and  re-tried , and got the same error
Downloaded  the MS Clean removal tool and  cannot find any  entries for gatwick /GAS / sbs populator
So no joy from that .net url that was  sent
Kev S
Did you uninstall SBS Populate using Windows "Apps and Features"?  Check if it still shows as an installed app?
Kev_Strickson
Nothing in : Control Panel\All Control Panel Items\Programs and Features
Nothing showing in Registry either under  local user - software  or local machine - software
Kev S
Before trying the following, maybe close and restart Windows and try a reinstall again?
If that doesn't work, using File Explorer with Options set to:
Show hidden files, folders and drives - checked
Hide protected operating system files (Recommended) - Unchecked
Navigate to Users -> your login name -> AppData -> Local -> Apps.
Expand each and every subfolder and look for any files referencing SBSPopulate.  There may be more than one such folder.
Copy any of these folders and files to another location, such as a USB or SD stick/card as a backup.  Make a note of the folder name containing these subfolders and files as you may need to retore to that location.
Be careful with the next step and only delete the folder and files referencing SBSPopulate.  Do not delete any folders or files that you haven't copied as a backup.
Please do not attempt the above if you have any concerns and do so at your own risk!
Kev_Strickson
No issues with getting  this in depth mate
Followed instruction backed up files
There was a  few folders in there that mentioned sbs deleted as requested
What was left was empty folders
Re-launched installer package  and same issue.
Looking in the folder there was a  2.0 folder installed and a few other blank foders
Have attatched screen clips
Kev S
Thanks Kev.
Sorry, my posts always assume basic IT experience/knowledge   ;)
If you've cleared and deleted all the folders that had any SBSPopulate data I've run out of suggestions.
Years ago the late Gary Jones suggested this approach when there was a malformed SBS-1 Populate install.  But I can't find the email which was about 15 years ago!
Sorry, I'm at a loss!
