May 12, 2024, 08:27:58 PM
Silhouette Request Please
Started by BLACKHAWK101, May 23, 2021, 12:27:59 PM
BLACKHAWK101
Hi Ian,
Can i please have the following Silouettes,
GL6T
FA6X
GA7C
Many thanks and regards
Steve Coulson
Quote from: BLACKHAWK101 on May 23, 2021, 12:27:59 PM
GL6T
FA6X
GA7C
Ian isn't on here too often but I don't think these two are official ICAO Type Codes?
GL6T
FA6X
BLACKHAWK101
Thanks for the information Mike,
Steve Coulson
Do you have the registrations or hex codes of the aircraft for which you want the silhouettes?
BLACKHAWK101
Hi Mike,
The aircraft in question are,
F-WIDE and F-WSIX both are Falcon 6X and acording to the ICAO the code for these will be FA6X these are the first two which have been built.
The GL6T which i requested is ICAO code GLEX so i will change the existing silhouette code to cover this one.
Many thanks for you time and help,
Steve Coulson
Thanks Steve
It looks like the Falcon 6X has yet to be allocated an ICAO type code thought it could be FA6X following earlier convention.
https://www.icao.int/publications/doc8643/pages/search.aspx
Let's hope Ian K sees your first post  ;)
