August 24, 2026, 11:07:58 AM
Silhouettes and Dual View Silhouettes
Started by Roadrunner, September 07, 2021, 10:16:10 AM
Hey Mike. Thanks for the list. Will crack on with that as and when. Many thanks
R :)
List of todo from RoadRunner
The following is a list of Types in my logs with no DV logos. I note your comments re work and such like but If I list them, they are the ones about in the local area.
C206
DA40  DA42  DA50  DA62  DV20
D250
DIMO  DISC  GLID
EFOX
G209  G12T
GY20
HUSK
M6  M7
MCR1
ME08
MOR2
P28R  P32R  P32T PA32  PA34  PA39
P68
PTS1  PTS2
S22T  SR20  SR22
SLG  SLG4
XA41  XA42
YAK42
Hi Richard
Have you a silhouette for a Maule M-4-210C?
No. Not yet, but I will by the end of the day.
Posted up in standard and DV format.
Enjoy
R :)
#51
Quote from: rikgale on March 18, 2022, 08:40:53 AM
C206
D250
DIMO  DISC  GLID
EFOX
G209  G12T
GY20
HUSK
M6  M7
MCR1
ME08
MOR2
P68
PTS1  PTS2
S22T  SR20  SR22
SLG  SLG4
XA41  XA42
YAK42
Hi Mike (roadrunner)
Please can you clarify G209? - there is no aircraft type code against this ICAO code.
Also, I am unable to do a DV for the DA50 - I am unable to find a top view for it. The few drawings that are out there that claim to be a DA50 are in fact a DA40. If you are able to find a 3-view of a DA50 please let me know.
Rik
p.s. M7 should already be in the gallery even if not in the ZIP - it is on my completed list apparently.
Roadrunner
Hi Rick,
G209 is a miss-type for G109 Grobb powered glider.
I have now found M7.
sorry for the errors
No need to apologise.
Thanks for the clarification
R :)
Hi Mike
Hope things are good with you?
Further clarification please? PA39? - there noting against this ICAO code. I checked PA36 / PA38 and they both have DVs.
Also, MOR2 is in the gallery.
I am about down to the PTS1/2, so if you have anymore please post them up.
Cheers :)
Roadrunner
Rick
I have 2 entries in my basestation.sqb file for PA39 and they are N39CR and G0LARE. I use Plane Base as my updated and both have PA39 as the ICAO designator.
I need to go to spoecsavers about MOR2 !
#56
Hi Mike
Thanks for getting back to me :)
N39CR is a Piper PA-39 - the ICAO type code for this is PA30. One of those where multiple similar types go to one ICAO type code. I would up date your DB to PA30 for those two.
R :)
p.s. - same a/c but with contrarotating props
"The Piper PA-30 Twin Comanche is an American twin-engined cabin monoplane designed and built by Piper Aircraft. It was a twin-engined development of the PA-24 Comanche single-engined aircraft. A variant with counter-rotating propellers was designated the Piper PA-39 Twin Comanche C/R." - Wikipedia
Roadrunner
Rick
Since my previous reply I have been looking at the IC AO DOC8643 and the correct designator for type PA-39 is in fact PA30, which you have done.
I have changed the ICAO info for these two in my databse.
Best regards
There is always something to tweak/change in these databases and always something new to learn.
Rik :)
