November 10, 2026, 10:39:39 PM
Windows 11 & Basestation
Started by Paul1, October 20, 2021, 09:05:17 PM
Paul1
Hi Mike
No problem will speak to you this afternoon
I've just spent an hour remotely connected to Paul1.
Then, towards the end of the session, no one appeared to be available so I had to disconnect.
I'll summarise what I found.
Basestation and ADU were running.  Some logos were displaying but not all.  Those that were missing were in the OperatorFlags folder with a matching code in the aircraft record.
On closing Basestation it automatically restarted which I assume was a batch file.  Closing ADU stopped the restart.
Paul explained he normally starts Basestation from a desktop shortcut.  On looking at the shortcut Properties, the target was in ProgramFiles (X86) whereas the previous posts implied it was in a nominated folder outside of ProgramFiles.  Such a folder existed.
On checking the OperatorFlags folder, with over 15,000 files, there were some odd sized files.
I zipped all the files and transferred them to my PC and ran BmpChk, results as follows:
BmpChk V2.0
Checking bmp files in I:/LCN Websites/Radarspotting/logos2
Dimension 83 x 20 for file 181AS.bmp is unusual
Dimension 94 x 22 for file 412FLTSC20.bmp is unusual
Dimension 86 x 20 for file 652SQNAACWildcat.bmp is unusual
Dimension 74 x 26 for file AA, AX.bmp is unusual
Dimension 85 x 21 for file Ambeo_35.bmp is unusual
Dimension 85 x 24 for file AS65black_8.bmp is unusual
Dimension 85 x 24 for file AS65blue_9.bmp is unusual
Dimension 90 x 20 for file BTTC680.bmp is unusual
Dimension 85 x 18 for file CARTIER.bmp is unusual
Dimension 60 x 20 for file CJM.bmp is unusual
Dimension 85 x 21 for file COKEGALX_28.bmp is unusual
Dimension 85 x 22 for file D11.bmp is unusual
Dimension 90 x 20 for file DA62_1.bmp is unusual
Dimension 85 x 18 for file DBR.bmp is unusual
Dimension 85 x 18 for file EBA.bmp is unusual
Dimension 85 x 18 for file EEX.bmp is unusual
Dimension 85 x 18 for file EFP.bmp is unusual
Dimension 85 x 18 for file EHY.bmp is unusual
Dimension 84 x 25 for file Enable_10.bmp is unusual
Dimension 85 x 18 for file ETR.bmp is unusual
Dimension 85 x 18 for file FCN.bmp is unusual
Dimension 85 x 18 for file FKG.bmp is unusual
Dimension 84 x 20 for file FKS.bmp is unusual
Dimension 90 x 21 for file Flairjets_1.bmp is unusual
Dimension 85 x 22 for file G-EMAA.bmp is unusual
Dimension 84 x 25 for file G-OCON_20.bmp is unusual
Dimension 93 x 21 for file GJS.bmp is unusual
Dimension 85 x 21 for file HeliairR22_1.bmp is unusual
Dimension 85 x 18 for file HIA.bmp is unusual
Dimension 21760 x 0 for file Hop.bmp is unusual
Dimension 85 x 18 for file HST.bmp is unusual
Dimension 87 x 20 for file HSV.bmp is unusual
Dimension 85 x 22 for file IAC.bmp is unusual
Dimension 85 x 22 for file IACFTS.bmp is unusual
Dimension 85 x 18 for file IL62.bmp is unusual
Dimension 85 x 18 for file JGA.bmp is unusual
Dimension 84 x 25 for file Kuki Heli R44_12.bmp is unusual
Dimension 85 x 18 for file KVA.bmp is unusual
Dimension 90 x 21 for file LWGE50P_15.bmp is unusual
Dimension 90 x 21 for file LWGE50P_3.bmp is unusual
Dimension 85 x 18 for file LXP.bmp is unusual
Dimension 85 x 18 for file MCS.bmp is unusual
Dimension 85 x 24 for file MFTAS65_1.bmp is unusual
Dimension 85 x 21 for file PDYGALX_17.bmp is unusual
Dimension 85 x 22 for file POLICE.bmp is unusual
Dimension 84 x 25 for file R44_3.bmp is unusual
Dimension 60 x 20 for file RFA.bmp is unusual
Dimension 85 x 18 for file ROK.bmp is unusual
Dimension 85 x 18 for file SOC.bmp is unusual
Dimension 89 x 20 for file SwedAFS102B_91.bmp is unusual
Dimension 84 x 25 for file SXNG-KLNJ_18.bmp is unusual
Dimension 85 x 18 for file TAV.bmp is unusual
Dimension 86 x 20 for file TC-GAP.bmp is unusual
Dimension 86 x 20 for file TC-GAP_101.bmp is unusual
Dimension 77 x 20 for file Trout99.bmp is unusual
Dimension 800 x 248 for file trustair-logo.bmp is unusual
Dimension 86 x 20 for file TUAF212FiloGLF4_102.bmp is unusual
Dimension 93 x 21 for file UA, RP.bmp is unusual
Dimension 85 x 18 for file VC10.bmp is unusual
Dimension 89 x 20 for file VOEB717.bmp is unusual
Test complete, 15564 files checked, 28 errors and 60 warnings
I deleted all the files with "File length mismatch" in the OperatorFlags folder in the ProgramFiles location.
When I went to restart Basestation from the desktop shortcut I got numerous error messages which suggested a corrupt setup.  It also suggested that Basestation had been running from a different location.
I asked Paul to restart ADU but received no reply.
I had no option but to disconnect the Remote session.
In my opinion, the operator logos/silhouette issue was caused by the rogue files in the OperatorFlag folder.  But I can't confirm this due to the Basestation launch errors and not knowing which Basestation.exe was being used when I first connected.  If it was the one in the discrete location, the cleaned up OperatorFlags folder needs to be copied to that directory.
As a footnote, I'm more than happy to undertake remote sessions but I do ask that the member remains available throughout.  Otherwise I can't get answers to questions and I'm uncomfortable being on someone else's PC without supervision.  This has happened a few times recently.
