May 01, 2026, 05:27:52 AM
ICAO designator 01
Started by AlanT, April 27, 2022, 05:56:44 AM
AlanT
Hi Steve
Any chance of working your magic on the above code please. It is a Cessna 305A.
Alan
DaveReid
Being picky, it's O1 rather than 01 (ICAO designators always start with a letter).
s92driver
Hi Alan,
Dave is correct.  If you search for "O1" in the gallery or my Zip file you will find it    8)
Steve
AlanT
s92driver
Mind you, having said you can search the Gallery for it I now know you can't as the search engine requires at least three characters.  So Alan, you are forgiven  ;D ;D ;D
However, if you put the full a/c name when posting in the gallery then when searching O-1 then some O1 images are found.
Quote from: s92driver on April 28, 2022, 08:01:26 AM
If you search Gallery using a wildcard character it will find "O1".
For example Search:
O1%
On S92Driver's Category will return:
https://radarspotting.com/forum/index.php?action=gallery;sa=view;id=38800
https://radarspotting.com/forum/index.php?action=gallery;sa=view;id=36792
If you use the same Search across all Categories you will get 7 files named "O1.bmp".
