October 25, 2026, 08:47:38 PM
ModeSDeco2
Started by Anmer, April 13, 2022, 12:51:00 PM
Oldfella
#15
Quote from: Anmer on April 16, 2022, 08:38:40 AM
Thanks for sharing your setup.
Can you enable file extensions and post another screenshot of your ModeSDeco2 folder?
And one of your bat file?
Anmar, attached are the two screenshots that you asked for. I changed the silhouettes to the OperatorFlags folder but still not showing up in the flights listing..
Noel
Oldfella
Thanks.  Unfortunately the file extensions are still not displaying.  It should be an option in Windows Explorer.
Is the directory path correst for your silhouettes folder and do you have bmp files there that match with the OperatorFlagCode field in Basestation?
Oldfella
Apologies Anmar, forgot about displaying the file extension setup in Windows. Hope the attached is suitable.
Went through both the OperatorFlags and Silhouettes folders and made sure they only contained BMP files. Still no luck.  :(
Noel
Oldfella
Quote from: Oldfella on April 17, 2022, 11:26:46 AM
Sorry Noel, I meant to reply but forgot!
Your first BAT file shows the Basestation.sqb file located in:
C:\data\BaseStation
Is that your "active" sqb location, the one that's being updated with matching OperatorFlagCodes that match the bmp files in:
C:\data\BaseStation\OperatorFlags
Oldfella
Sorry Anmer, finger trouble my end, accidentally posted the sample AirSpy dongle batch file that was in the folder. The correct batch file I use is this attachment. The silhouettes point to the OperatorsFlags folder in the BaseStation folder in C; drive. Tried various combinations but still no luck getting to show the silhouettes in the "Flights" column in ModesDeco2.
Oldfella
Jumping in here - hope that's OK.
Your .bat file looks wrong to me, it should be:
-- silhouettes c:\BaseStation\OperatorFlags
i.e. no '--' in front of the path to the OperatorFlags folder
Oldfella
Give that man a beer  ;D
Thank you Triple7, well spotted. I have looked at that batch file dozens of times, tried all sorts of combinations and just didn't see the error. Now working as expected.
Thanks again. Appreciate your help.
Noel
Oldfella
Quote from: Triple7 on April 20, 2022, 10:43:38 AM
Thanks Tim, well spotted.
But what took you so long  8)
Quote from: Oldfella on April 20, 2022, 11:14:18 AM
Hi Noel
Can I ask what version of Windows you're using?  64 or 32 bit?
Oldfella
Good morning Anmer (it is here), down at Berrima, NSW for a few days. Sharer code gr on PlanePlotter,
Running a HP Probook laptop with Win 11 Pro, 64 bit.
Need to update my silhouettes file, missing a few.  :-[
Thank you and Tim for your interest and support.
Noel
Oldfella
QF1
A quick update on my original post as I now have ModeSDeco working successfully and feeding Basestation and PlanePlotter.   Thanks to Anmer for your help with the Basestation setup - much apprecaited!
The problem seems to have been the incorrect .dll files (probably ftd2xx.dll and msvcr100.dll) that I had installed.  As I have a new 64 bit Dell notebook I thought I needed to download the 64 bit versions of these files, but when I deleted tehse and used the 32 bit files the program worked perfectly.  This was alluded to by Sergsero previously and that helped me to fix the problem.
Thank you also to others who suggested possible fixes.
Mark
abcd567
#26
Quote
@echo off
cmd /c modesdeco2.exe --gain 49.6 --freq-correction 0 --location -33.xxxx:150.xxxx --web 8888 --db C:\BaseStation\BaseStation.sqb --silhouettes C:\BaseStation\OperatorFlags --frdb C:\modesdeco2\flightroute.sqb --pictures C:\BaseStation\Pictures --sbs10001 10001 --beast 30005
PAUSE
exit
Above format of batch file results in a very long line of arguments, most of which are not directly visible when file is opened in Notepad for editing/browsing. Scrolling to right is required to see all the arguments. Even if "Wrap Text" is used, the lines wrap at random points, and not at the end of arguments.
A better format is given below, which has one argument per line, each line terminated by character ^ (Carat, Circumflex accent, Shift + 6 on US & UK Keyboards)
In this format all arguments are directly visible without need to scroll right, as below:
IMPORTANT:
(1) Leave space between argument and Carat symbol ^
(2) Do NOT leave any space after Carat symbol ^
(3) The last line of argument should be WITHOUT Carat symbol ^
(4) No blank lines between arguments.
@echo off
cmd /c modesdeco2.exe ^
--gain 49.6 ^
--freq-correction 0 ^
--location -33.xxxx:150.xxxx ^
--web 8888 ^
--db C:\BaseStation\BaseStation.sqb ^
--silhouettes C:\BaseStation\OperatorFlags ^
--frdb C:\modesdeco2\flightroute.sqb ^
--pictures C:\BaseStation\Pictures ^
--sbs10001 10001 ^
--beast 30005
PAUSE
exit
Is anyone currently running ModeSDeco on Windows with an SDR receiver feeding Basestation?
Is so, can they share their setup?
s92driver
I used to occasionally run ModeSDeco feeding Basestation on my laptop, so thought I would try it out once I saw your request.  Well it wouldn't run on my W11 machine.  The good news is that a after a bit of searching for advice I got it running again.
By following the advice on this video everything worked:
https://www.youtube.com/watch?v=LWyswHcE5dU&t=130s
Steve
Thanks Steve, much appreciated.
