August 24, 2026, 11:26:51 AM
Photograph programmes
Started by Ospreyv22, August 20, 2022, 06:42:01 PM
Ospreyv22
Evening all,
I was just wondering if anyone on the group could recommend a good quality Photo programme for the odd touch up and edit of photographs,
For instance like removing a rogue crow that got in the way of a shot i took of a C135 on the ground,
I'm not a big lover of messing with photos but sometimes the odd tool to sharpen or clean a photo can make a difference.
I thought i would ask on here first before trawling around and to get recommended advice first off members who have tried and tested and used
such programmes.
All replies with help and advice appreciated.
Ian (Osprey22)
Smudger98
#1
Hi, I have used google`s picasa(3) for years - I am given to understand this will be replaced at some point with google photos?.. I use it as not web linked just pc stand alone..
The current free software has all the basic edit type tools for cropping etc already built in. Downloadable still - type picasa in google..
https://picasa.en.uptodown.com/windows/download
HTH.
Smudger.
I too used Picasa but thought it was no longer supported?
Corel Paint PaintShop Pro is a low cost app that may be a good alternative.
Smudger98
#3
Quote from: Anmer on August 21, 2022, 07:54:38 AM
Still use picasa here Anmer, still free to use..  I edit in picasa then upload the edited to my Flickr account for the web..
DaveReid
It may be a bit OTT just for the odd touching up, but AFAIK you can still download Photoshop CS2 (legally) for free, courtesy of Adobe.
The GIMP, also free, is worth a look too.
Faramir
GIMP is a open-source (free) alternative to Photoshop and has lots of possibilities to match it. Well maintained and a good userbase for support. You can get it via this link if you want to try it for yourself.
Ospreyv22
Hi Guys,
Thanks for all the replies and possibilities that i can take a look at.
Thought i would just ask as there is so many programmes out there and was really
wanting to know what others on the group worked for them and there spec on them.
Thanks again for the replies and info it is much appreciated.
Regards and best wishes.
Ian (Ospreyv22)
