November 10, 2026, 10:09:08 PM
Latest 9H- hexcodes not showing
Started by keef777, February 03, 2023, 04:56:53 PM
Faramir
The --filter-nocountry option should be added to the command line for ModeSDeco. I'm guessing you use Windows running the the ModeSDeco program . If you have a shortcut on your desktop for the program, selecting it and then clicking with the right mouse-button should open a menu. The bottom option (properties) should give you a window where you can see the command line for the program (target). That should tell you how the program is started (with a command line or a .bat or .cmd file)
If the program is started directly from the target line then the --filter-nocountry option can be added there or if it needs to be put in the file mentioned on the target line.
geoffjlee
Thank you Anmer that would be great , I,am working until Friday and then I,am off 4 days hope this helps you anytime then would be great .
        Thank you for your help if you need to email me off anytime please do .
        Regards Geoff
Hi Geoff
Maybe we can arrange this for next weekend or early the following week?  I'm around most of the time.
I've emailed you how to set this up.
geoffjlee
Thank you Saturday or Sunday would be good , no email has come yet . It should be the with @gmail.com at the end .
Thank you again Anmer for your help .
Regards Geoff
geoffjlee
Anmer it ok found it thank you Regards Geoff
geoffjlee
Just like to say a big thank you to Anmer for all of his help and time in helping me out .
Jambo
Thanks to everyone on this thread (especially s92 Driver) for the answer to the Wizz Malta issue.
I have updated my Modesdeco file, as well as the countries file, and I can now see 9H-WAH passing me in Edinburgh on my basestation screen.
Neil
Mark16
Noticed Wizzair aircraft with 9H-  reggies now appearing
Many thanks,
Mark
