November 23, 2026, 12:09:52 PM
Another BaseStation SQLite Question
Started by Pete, March 18, 2023, 02:05:44 PM
Is there a way of checking for this case and changing/forcing the "1" to be the correct format for the boolean (TBH - I am not sure if it should be a string or a number)
jakems
Interested is a boolean and is defined in Basestation as:
Interested boolean not null default 0,
So it should never have a value of null. As a boolean the test can be = true or = false. As Dave says SQLite does not enforce strong typing so depending on the app you are using you may find you get more consistent results using them. Please note I did say may!
Steve
Pete
Hi Dave
Apologies for the delayed reply as I've been away from my computer.  I've tried your suggested query and unfortunately, it returns a third row with 66 entries in it.
Is  there anyway of developing the sql script to produce a list of those 66 entries?
Pete
DaveReid
Probably.
What are the 3 values for Interested in your results table ?
Pete
The three rows have returned the following:
Rec No   Interested   count(*)
  1            (a Tick)     34439
  2            (blank)     41254
  3            (a Tick)     66
It seems (to me anyway) that the 66 entries in row 3 have had something other than a '1' entered into them.
I hope this helps.
Pete
DaveReid
SQLite Personal is telling us that there are two different non-zero values in the Interested column, both being interpreted as True - but it won't tell us what those values are.
Try the following (back up your SQB first):
Update Aircraft Set Interested = 1 where Interested <> 0
Then re-run the original query and report how many rows/values you get.
If you use DB Browser it shows the actual values in the Interested column whereas SQLite Expert doesn't.
Using DB Browser you can sort on the Interested column which should show the records containing values other than 0 and 1.
Pete
Thanks to you both.  The third row has now gone completely and rows one and two display numbers I would expect to see.  The database has changed since I gave you the original figures so that's to be expected.  Thanks again.
Pete
