May 01, 2024, 01:32:22 AM
Active Display has stopped working on Win 11
Started by terrywadeairbus, March 09, 2024, 09:25:09 AM
terrywadeairbus
I know AD Lite is an old program and has no support, but AD Lite has always worked fine on both my Win 11 PC's until a few weeks ago.
I've tried numerous times uninstalling and re-installing the program, but I keep on getting the error attached.
I'm wondering if it's caused by a Win 11 update?
Has anyone else had similar issues running AD Lite lately and would anyone have any idea of a possible fix?
Thank you
Terry
Check you've "mapped" ADLite to the correct database.
terrywadeairbus
Hi Anmer
The path is set as in AD Lite
C:\Kinetics\BaseStation\
AD Lite appears to work on my laptop running W10
Terry
terrywadeairbus
AD Lite just isn't working on my Win 11 PC's. I can still produce logs from it, but it will only show 1 aircraft then the earlier message posted comes up?
Anyone else had this issue with Win 11 and has anyone any idea of a possible fix?
I tried to roll back the latest Win 11 update, but it's gone beyond the 2 weeks to do this!
Terry
terrywadeairbus
Having tried ages to get my AD Lite working on my Win 11 PC, I've managed to get it working (see below) whether this
will be a fix that will last time will tell!
I'm using a USB stick on my Win 11 PC running SBS-1 and BS , on the USB stick I made a folder containing
the SBS BMP FLAGS, OPERATOR FLAGS, BS SQB and Reference files only, I've mapped AD Lite to this Folder on the USB
stick and AD Lite appears to be working, see attached screenshot.
Obviously if ADL keeps working I'll have to update the SQB on the USB stick.
I'm not sure why ADL works through a USB stick and not on the C drive of my PC?
Terry
Thanks for the update.
I still think it's a "mapping" issue to the active sqb file.
I've emailed you about taking a look with you later this week.
