September 21, 2026, 03:08:05 PM
Base station reporter editing issue
Started by webmonkeyuk, June 25, 2025, 10:43:29 PM
webmonkeyuk
Quote from: Anmer on June 27, 2025, 08:26:17 AM
Quote from: webmonkeyuk on June 26, 2025, 10:35:50 PMAppreciate the offer but as you said earlier that editing the daily session list log is not possible there's probably not much I can do about it. 😬
The bit I don't understand is why your Sessions are empty?
The sqb in the Virtual Store should update.  Don't copy the one from Program Files (x86).  That one doesn't get updated with locally received data.
Yes I made the mistake of copying the sqb from the c: program files kinetic folder into the virtual store last night. I only started using the new sqb file about two days ago so that's why the sessions list was empty 😊
And after I copied over the sqb file from the program file folder it wiped the sessions list again 🤣 (rookie mistake) that's why I was wondering which location is used to update the sqb. Now I know it's the virtual store directory 👍
