June 09, 2026, 08:31:48 AM
Basestation Version 175 Released
Started by Anmer, October 23, 2012, 05:37:22 PM
There's a new version of Basestation - Version 175 - available for download from the Kinetic website:
http://www.kinetic.co.uk/newsite/basestationdownloads1.php
In the absence of a Release Note (one day, maybe, one day!), I have no idea what this includes or fixes.
There are two Zip files.
BaseStation-175-exe-only.zip - just the Basestation.exe
BaseStation-175-CDROM.zip - full install file.
If you're running a recent version, just rename the existing Basestation.exe "Basestation.exe.old" and copy the new one to the Basestation folder.  Restart Basestation.
Ian K
Fixes (apply to SBS-3 only)
* Saving of audio mixer settings to Non Volatile Memory for channels 5 and 6
* Fixed button to restore default radio  settings for the Non Volatile Memory.
The release notes are buried in the CD-ROM zip in the Basestation folder - ReleaseNotes.txt.
Here are all the updates for 2012 - please note AirNav.  :)
*        BASE STATION RELEASE NOTES        *
*           BS Version 1.2.3.175           *
*           Released 25/09/2012            *
*           BS Version 1.2.3.174           *
*           Released 04/09/2012            *
* Fixed the pop-up hint text for the buttons
  on the radio control panel
* Fixed an issue with selecting channels
  5 and 6 on the radio panel
* Fixed problems with using channel 5 and 6
  volume controls on the audio mixer panel
*           BS Version 1.2.3.173           *
*           Released 30/08/2012            *
New Functionality (applies to SBS-3 only)
* Increased number of SDR channels to 6.
  Requires firmware L_0201_0000_0116_R_SBS3
* Radio control panel redesigned to
  accommodate the extra channels
* Moved the audio mixer controls to a
  separate window. This can be launched
  from the internal radio menu or by
  using the keyboard shortcut CTRL-ALT-M.
*           BS Version 1.2.3.172           *
*           Released 25/05/2012            *
Fixes
* Removed vertical bar from ACARS messages
  which was used to represent a new line.
  Instead added ACARSNewLineStr setting to
  the [Settings] section of INI file
  (default is a single space character)
* Fixed an issue with the selected aircraft
  not being expired from the aircraft list
*           BS Version 1.2.3.171           *
* Added date column to ACARS window
* Scroll direction is selectable for the
  ACARS window
*           BS Version 1.2.3.170           *
*           Released 17/05/2012            *
* Support for ACARS Decoding on up to 4 SDR
  channels simultaneously (with SBS-3 only)
  Please ensure that SDR channels to be used
  for ACARS are set to AM demodulation
  and that the squelch and mute are off.
  Requires firmware L_0109_0000_0115_R_SBS3
* ACARS message display window added
  (for SBS-3 only). Activated by menu or
  using keyboard shortcut CTRL-ALT-A.
* ACARS data available on socket 30008
  (for SBS-3 only)
* ACARS and AIS data available on the raw
  data socket 30006 (for SBS-3 only)
*           BS Version 1.2.3.168           *
*           Released 17/02/2012            *
New Functionality
* Support for stand-alone operation
  Stand-Alone Data tab and Radio tab
  added to the Non-Volatile Memory Settings
  window for the SBS-3
* Mode A/C data pass through option
  to port 30006 (applies to SBS-3 only)
* Improved network performance
* Stereo audio streaming for SBS-3
* Preset tuning on SBS-3 now adjusts tuner
  centre frequency when required, as well as
  the SDR frequency
* Ability to set the name for radio stations
  on the SBS-3 radio control panel
*           BS Version 1.2.3.165           *
*           Released 16/01/2012            *
* The SDR control panel can be resized
  and has scroll bars. BaseStation remembers
  the size and position on shut down
* BaseStation saves the SDR settings for the
  SBS-3 (frequency, squelch, mixer etc.)
  on shut down
* Preset buttons implemented for SBS-3
  radio control panel
* Frequency lists implemented from Built-in
  radio menu, toolbar button or radar
  screen pop-up menu
* Mute and volume up/down toolbar buttons
Although not mentioned in the Release Notes, the BasestationReporter.exe in the CD-ROM zip is new.  The splash screen is still labelled 1.0.0.28 but it's a slightly bigger file and includes a bug fix.  There may be others but this is the one I've found.
If you open Reporter and select Sessions, the Field drop down box now works as it should.  Before it never scrolled.   ;D
Just copy the BasestationReporter.exe file and replace in the same way as the Basestation.exe.
Mature68
Thanks forthe info and updates
Brian
