September 05, 2026, 03:57:32 AM
PlanePlotte 6.7.6.9 Released
Started by Triple7, July 11, 2026, 06:29:32 PM
From Bev:
PlanePlotter version 6.7.6.9 is on the web site now.
http:www.planeplotter.com#download
---Usual boilerplate---
If you have a version-specific firewall or security system, you may have to reassure it that the new version is permitted to access the Internet. Be aware that increasingly, security systems treat any new file as a threat without any justification except that it is new. Please don't write to me about it; write to your security system provider and ask them to make their program smarter.
The following are the changes since the last published version 6.7.3.9
done in 6.7.4.1
initialise VDL2 pointer
done in 6.7.4.2
add accelerator keys "H" (Halt processing) and "K" (Kontinue processing)
done in 6.7.4.3
handle GS with non-standard port numbers
Alt-1/2/3 toggles OpenIP overlays
done in 6.7.4.4
accept the port number in the GS list - may help CG-NAT GS
prevent reverse orthomorphic projection from producing zero height or width map boundaries
done in 6.7.4.5
prevent excessive map zoom out
done in 6.7.4.6
update SBS receiver mode
done in 6.7.4.7
accept BaseStation MSG format messages from dumpHFDL
done in 6.7.4.8
View..Messages shows messages from dumpHFDL
done in 6.7.4.9
protect reentrancy in Internet check
done in 6.7.5.1
new version of Inmarsat ephemerides
done in 6.7.5.2
QNH : when nearest METAR is out of date (>2h) search next nearest airports up to max of five or 100nm
done in 6.7.5.3
new "Options..Message view" - select which message inputs are displayed in the message window
done in 6.7.5.4
provision to read "HF Selcal to Registration" definition file into SQB field UserString3
look up and display Registration from HF Selcal
done in 6.7.5.5
add option to accept unpaired Mode-S positions within 5 minutes of a previous position report
done in 6.7.5.6
User defined Selcal UserString (default 3)
handle 32 Selcal tones instead of original 16 tones
done in 6.7.5.7
handle changed Celetrak default TLE format
done in 6.7.5.8
copy (= left click) and paste (= right click) function in View.Messages for HF Selcals
display Mode3A/3S history graph function ('T')
use screen centre for QNH, not outline centre if the chart/outline is displaced.
new Options..Alert..TCAS..Ignore "no data" TCAS
done in 6.7.5.9
correct time zone error in QNH retrieval
done in 6.7.6.1
make doubly sure that isolated first position reports cannot be shared
prevent isolated first position reports from hypersharing
prevent positions received by hypersharing from seeding isolated subsequent position calculations
done in 6.7.6.2
restrict seed positions for CPR2 to type 6
done in 6.7.6.3
revise precedence of sharable condition
done in 6.7.6.4
separate share enables and potentially ambiguous CPR solutions
done in 6.7.6.5
initialize ambiguous flag for all message types
done in 6.7.6.6
restrict UDP and shared data from seeding CPR positions
done in 6.7.6.7
restore corrupt TCAS enable flag
done in 6.7.6.8
suspend positions from MV payloads in DF16 (frequently suspect
check CPR coordinate change is cognate with the time interval
done in 6.7.6.9
measure CPR position change more precisely
shared reports not tagged as ambiguous - prevented by foreign share code from sharing and seeding position
limit CPR decodes to real coordinates
Bev
COAA
Some additional comments from Dan Henry:
Hi all,
As you can see, Bev has been very busy.
For those not familiar with some of the acronyms, all the references to CPR stand for Compact Position Reporting.  Those are all PP software tweaks in how PP actually decodes full ads-b DF 17 broadcast positions.  They are related to the previous "isolated Position reports" feature, which has been completely overhauled.
There were several other significant changes designed to get rid of other bad positions.  The DF16 reference is how aircraft chatter back and forth with ACAS/TCAS.  That's part of the TCAS (Traffic Collision Avoidance System?) feature.  It turns out that many of those DF16 positions PP has always used are very unreliable.  PP now ignores them completely for position, but still of course does the TCAS alerts when needed.  Those alerts are still valid.
The hypersharing changes are designed to stop people from sharing bad positions directly, that then might end up getting uploaded by the person that received that bad position from another person.  Those used to sneak through.
There were also several changes for "sanity checks" on positions themselves.  Because of the incredible number of messages, PP would occasionally decode a message it thought was valid (with correct CRC), but actually decoded with completely invalid lat/lon positions.  Those are now completely ignored so you won't see them locally, and they will not possibly get uploaded to the server.
So, let's just say that there are a lot of good updates that improve position quality in many different areas.
As a reminder, PP is always a bit experimental.  While it has been heavily tested, having more people run this new version will probably identify at least one thing that might need to be tweaked.
Thanks Bev for all the work on this!
-Dan
