November 15, 2026, 09:52:40 PM
Blurry silhouettes/flags on a modern 4K display setup
Started by skaw, September 02, 2026, 09:58:51 AM
skaw
Hey,
is anyone else using VRS or similar software utilizing the 85x20 Silhouettes & Flags on a modern setup with a 4K display? Probably Windows scaling set to 125%, 150% or hihger?
Have you found a satisfying solution for the blurred rendering of the Logos in the browser caused by the scaling setting?
I tried a few ways like the Stylus extension to set specific CSS rules for VRS regarding 'image-rendering', i tried a tweak inside the browser settings but that just reverted the 150% scaling back to 100% which is good for a crisp BMP logo but bad for daily browsing.
I also tried to change settings inside VRS to make use of bigger BMPs like 170x40, following this here:
https://www.virtualradarserver.co.uk/documentation/CustomContent/ChangeSettings.aspx#Miscellaneous
but somehow that didn't work out..It did not display the whole 170x40 logo but a centered 85x20 part inside of it..
How do you deal with this? Have you noticed this at all? Does it bother you?
Can you post a screen capture of the pixalated bmp files?
skaw
yea, sure..
Browser zoom set to 100%
Put a BMP view in the windows app at 100% for comparison. The browser renders the BMP at 150% size and of course uses a filter because of the windows scaling setting.
You cannot view this attachment.
EDIT: Download the attached picture to see it the best way.
Maybe it's me, but I don't notice any blurring in the screen capture?
skaw
Fair enough. I suppose some people are more sensitive to it than others.
Perhaps you notice sth. different in your PS/Gimp/whatever when you zoom into one of your logos. Basically the same thing. You/we make these crisp logos for 85x20 and thats the only size where they look really good.
Quote from: skaw on September 02, 2026, 03:27:42 PMYou/we make these crisp logos for 85x20 and thats the only size where they look really good.
BMP files don't scale.  BaseStation uses a bmp file format, as do apps that came along afterwards, such as VRS.
"Horses for courses" as they say!
skaw
True. Problem is the Windows scaling. This forces the browser to render the 85x20px BMP at 127,5x30 ...or it just zooms in...anyway, the BMP gets scaled x1.5
skaw
Then i have a crisp clear 85x20 BMP.
But thats a pain in the ass on a (42") 4K UHD display because everything is SUPER tiny and hard to read.
I know why it happens, i just wonder how other handle this ...issue...if it's an issue for anybody else at all  ;)
At 100% does VRS expand to fill the entire screen?
Does your Windows install recognise the actual screen?  Are there loaded drivers for it?
I don't have a 42" screen so can't test myself.
