November 26, 2026, 10:39:08 PM
Good range with SBS-3
Started by viking9, February 15, 2012, 01:12:32 PM
Hi Billko
Are these the Jim M-75 preamps:
http://www.mlands.co.uk/acatalog/Accs_Pre-amps.html
You can use these between the sbs-3 and antenna.  Try it and see if it makes a difference, making sure you set the frequency range on the preamp.
They eat batteries.  :(
shakysen
Hi Mike. Yes they are the jim type Would it be ok to place a short patch lead between the amp-sbs?  or adapter ie BNC-SMA?
In any case will try it out . I will keep you informed
        Billko
Yes, a short patch lead should be fine.
shakysen
Morning All.I was wondering what range you  are receiving on the inbuilt radio's ?.  I know its a wide ranging question  but what are you hoping for ,and what would you be happy  with.
        Billko
