August 25, 2026, 09:12:32 PM
Moonraker Aerial
Started by cyril, February 16, 2012, 09:45:39 PM
OK, so you got the preamp kit at £129.95 plus the antenna at £54.95?
There was a known problem (which I mentioned in my review) with the preamp which Kinetic said was fixed.  Basically, the preamp wasn't working in some situations which sounds like your problem.
Call Kinetic tomorrow and ask to speak to Chris Taylor.
shakysen
 Hi Again mike. Its is the pre amp with it connected  cambridge,south.newcastle north, liverpool west, east poor. same with it disconnected
        Billko
You may have the problem that Kinetic was fixing but the LAM stock may be old?  Call Kinetic tomorrow.
shakysen
 Will do Anmer .Im I asking to much from it Mike? 200 NM?
                                                            Billko
If you have a good horizon, 260nm should be possible, it's what I get
shakysen
Hi All .Put Toms ground plane idea up today increased range Upto luton
                                                               Billko
During my testing, if power to the preamp was removed for any reason, the preamp didn't kick in again when power was restored.  The only way the preamp would work was to remove and reconnnect the antenna at the preamp.
This was reported to Kinetic who said it was fixed in the "production" kit.  But others have reported similar issues:
shakysen
 Morning Mike. yes They said they had fixed it.Will I beable to reset from bias tee?
shakysen
 Hi Again. Im 4 miles n.west from the Ottringham Transponder. Would you settle for range upto Luton, Edinburgh?. Mike
        Regards Billko
        B
Hi Billko
If an antenna is located in a good position and the coax is suitable and the run is short, one could expect a range of, say, 260nm or further.  The addition of a preamp won't necessarily improve the range but should deliver weaker signals and, consequently, more contacts.  That's my personal experience, both with the Elad preamp and the Kinetic kit.
Unless you can easily get at the preamp, it may be a challenge to test that the Bias-T is powering it.  I was able to run successive tests and powering down the pre-amp reduced the contacts.  Powering it back made no difference until I removed and reconnected the antenna at the preamp which is OK for testing but not for a "production" setup.  That's the problem I reported and KInetic says is fixed.
The Kinetic kit represents good value and as long as everything works to spec, it should extend range and contacts for those still using the supplied magmount.
Do a simple test.  Remove the Bias-T power and see if your contacts reduce?  Then apply the power again and see if they increase.  If they don't, something's not quite right.
shakysen
Hi All.  Had enough of playing with antennas!!. The reviewed Items are in situ antenna 40 ft.Gatwick to the south, aberdeen to north, irish sea,west, coast of netherlands east. When i find out How to do a plot will post
        Billko
Quote from: shakysen on March 26, 2012, 10:55:19 AM
Download and install SBSPlotter from jetvision.
Unzip the files, read the readme.txt file and start building a plot.
Any questions, please ask.
