October 29, 2026, 11:04:44 AM
The TMRF-1090 - A Personal Opinion
Started by Anmer, March 14, 2013, 02:54:54 PM
alpey
Hi Bethsy
A shot of France UIR (W Sardaigna) show your antenna coverage............... super  :)
Regards.....Alain
Beast, PlanePlotter (GS/MU AP)
Bethsalem
Alpey, thanks for posting your screenshot.
I reckon the top of my apartment block is almost 800 feet above sea-level, so it's no wonder, I suppose, that an unobstructed view out to the Med would show this sort of range.
Stephen
Chris-G0WTZ
A simple comparison of the supplied Puck/SBS antenna and the TMRF base antenna same location using the same Puck
Thanks to Anmer for help with the outlines :-)
http://www.kinetic.co.uk/forums/viewtopic.php?f=1&t=16159&sid=00e25a0040b8ccefb4d18721571bd29d
I've copied the images as those who aren't members of the Kinetic forum will not see them.
Thanks for that Mike - I did eventually remember my Kinetic login but that makes it easier.
Surprised at low range for default antenna. I'm sure my SBS-1e gives me more than that with magmount in loft  (just started to run SBSplotter to check).
I'm wondering what an external TMRF base antenna would add? And whether it is worth the cost of the antenna plus fitting.
Well worth the cost Ian
Ive had mine up almost a year both antennas have stood the bad weather and work well.
All equipment from Taylormaderf and fitted by local erector for TV's
mike
Quote from: IanH on January 03, 2014, 08:44:34 PM
I guess it depends where the antenna is located.  I got more range with the TMRF when I was testing it than Chris appears to be getting. And my location is 100 miles further north.
Chris-G0WTZ
Thanks for copying the pics Mike
I tested these to demonstrate to a customer at Elstree and the readings where only over half an hour!
I just thought others might like to see the plots
I have just got a nice pile of antennas to test and will be doing that over the coming weeks.
Keep an eye on my website for the results
Last Wednesday, after a horrendous journey down the M1 (rain, sleet almost snow) I turned up at Elstree to buy a TMRF-1090 from Chris. Took one away to avoid postage. The antenna is at a good price at the moment:
http://www.taylormaderf.co.uk/page47/rapidcart-61/store.php
Chris was very helpful and clearly busy that day so hopefully business is good. But remember if you do visit, his office/showoom is in a hangar - if you visit on a cold day, dress up warm as my wife found out  ::)
Now I need to organise a man to put this antenna on my chimney.
lorrebreaker
I'm considering purchasing one of these & to have it mounted on the chimney, which cable would you guys advise getting?
I've tried searching for the CS-29 on the talormaderf site but cannot find it  (i may be having a senior moment)  ;D
Lee
lorrebreaker
Quote from: Anmer on July 18, 2014, 07:12:22 PM
Phone Chris Taylor at TM RF.
Done & i now have it installed on my chimney and it's making a huge difference.
Thank you
Lee
Not a polar plot but a snapshot in time of contacts on an SBS-3 via a TMRF-1090.
Had the antenna installed on the chimney Wednesday and dramatically improved reception - out in the open and 10ft higher than the magmount in the loft.
Limited view to the South because of the hill my house is on but that same hill provides a clear view to the North. Most of the contacts are high altitude but there's a couple around Manchester at FL80.
Polar plots to be added.
Thanks for the update Ian, looks very good.
Can't wait to get my external antenna installed when I move.  Only sea to the south of me from 90 to 270 degrees.
Truetrack
Quote from: Anmer on October 03, 2014, 06:27:42 PM
Wow -  what an opportunity half the arcing horizon out to sea
but what a pity again
that you seem to scorn with the world of MMSI, I mean Marine AIS tracking
sorry Mike , I just could not resist
best regards
Klaus
