May 25, 2026, 03:52:53 AM
Help With Networking SBS-1E
Started by radiowaves, July 30, 2013, 06:11:56 PM
I think you need to reset the Lantronix interface back to the default SBS IP address of 192.168.1.170.
I can email you a utility but you may subsequently have to change the IP address if the default ins't compatible with your local network.
Cherryx
Hi Anmer,
thanks, but did not help.
I changed the IP of the SBS back to 192.168.1.170 / 255.255.255.0
Does your utility do anything else? (if so, it should be no problem, network is 192.168.1.0/24)
What I found with the MMS2 client: While Basestation is running, it cannot connect:
14:41:35 | [reader][i][0]Connecting to SBS1 receiver on 192.168.1.170:10001
14:41:36 | [reader][e][0]Could not connect to 192.168.1.170
and after closing BS:
14:41:41 | [reader][i][0]Connecting to SBS1 receiver on 192.168.1.170:10001
14:41:41 | [reader][i][0]Connected to the receiver, authenticating
that's where it's stuck (except for the session ratio messages).
Anything else? Could it be some settings in the serial section?
Oliver
I've emailed you the utility (Zip).  It is a large file so let me know if it doesn't arrive.
The email has full instructions.
Cherryx
It got back to you.
How large is it?
I will send you an alternate address via PM.
Oliver
Cherryx
Not sure what the utility did (changed some other values besides Network), but it works!
Thank you so much for your help :)
Oliver
The utility sets the Lantronix device back to the Kinetic default settings.
sammylad1
when connecting sbs-1e via network does it have to be powered by plug or usb..
Quote from: sammylad1 on May 17, 2025, 12:35:44 PMwhen connecting sbs-1e via network does it have to be powered by plug or usb..
From memory you can either use a USB cable or a DC power supply.
Make sure the slider switches are set to Use Ethernet and Use USB power.
sammylad1
sammylad1
#24
what is the difference if its usb or internet...and should the connection from internet to sbs-1e just keep connecting then disconnect.?
sammylad1
ok i have connected the usb to phone plug it seems to be ok..for now anyway
Quote from: sammylad1 on May 18, 2025, 02:19:37 PMwhat is the difference if its usb or internet...and should the connection from internet to sbs-1e just keep connecting then disconnect.?
By connecting the SBS to your local network you can run BaseStation on any Windows device that can connect to the network.  The SBS can be far away from the PC.
sammylad1
ok ..Anmer
thanks for reply i thaught it might give you more distance for aircraft on the base
station....
sammylad1
Quote from: sammylad1 on May 18, 2025, 05:14:21 PMok ..Anmer
station....i mean more aircraft
No, you won't see more aircraft.  But it does give you the option to place the SBS and antenna in a (potentially) more favourable location, such as a loft.  Then connect via Ethernet to a network access point which could be WiFi enabled.
