May 28, 2026, 11:19:05 AM
Sending data to FlightAware via PlanePlotter
Started by satcom, September 25, 2013, 08:38:51 AM
Saudistu
Hi Ian,
Same issues that I am having. It keeps dropping from "live" to "today", and I am only showing around 800 aircraft per day on FlightAware, yet more than 2000 in Basestation. I tried the direct feed from the SBS-3, but that is no good as you cannot then use Basestation. It's either feed FlightAware, or watch Basestation. Why they cannot take a different feed like Planeplotter does, I do not know. Maybe a newer Firmware could fix that issue. All in all, it's been a frustrating experience. I am a SMU for Planeplotter, and all the data works fine, so it seems the problem is likely at the FlightAware end of things.
Regds.....Stu
Ian K
Thanks Stu
I'm glad it's not just me then. I don't have an SBS-3 so I can't try an alternate way of sharing.
Bethsalem
Quote from: Ian K on October 18, 2013, 03:24:13 PM
I'm also sending data but the stats only show that I have shared 88 aircraft today,when in fact it should be over 2000 ???  also it is not showing Live next to my name despite passing all the PP network tests.
any thoughts ?
Yep, the Texans don't like Chelsea supporters either  :P
charliebrown
At present I'm sharing data with PP and FR24.
Am I able to share data with both FR24 and FlightAware at the same time from my PP and SB1er setup ?
It would appear from the sharing options in PP "Sharing" that you can only choose one or the other.
Charlie
Ian K
Pretty certain you can't share to more than one.
fidaeextra
Hello Friends,
This weekend make the configuration and will be the first sharer for FA, for South America....
I am search all the information posible about PP, in special how setup the Map....
cheers
Quote from: charliebrown on October 18, 2013, 05:17:56 PM
Well, it's possible, but not from within PP, I share with FR24 using their own app - http://www.flightradar24.com/software and use PP to share with FlightAware.
Ian K
I posted the question yesterday about the 'Today/ Live' situation over on Flightaware forum but no reply yet
My Stats did change to Live yesterday evening but again showing as Today despite supposedly feeding data since 8am :(
Bethsalem
Ian, try their "live chat". I did this because their website wouldn't allow you to create a flight crew. I chatted online to Support who documented what was wrong and it was fixed in a few days.
Ian K
Ian K
Do you have a link to the live chat ? still can't find it
Bethsalem
Ian, look on the Home Page on the left and you'll see the "Contact" button, press this and then look for "submit on the web". This takes you to the live chat portal.
Ian K
I spoke to support today and they are aware of the problem regarding data not being received and the Today/Live problem
The developers are looking into it and will hopefully release an update soon
