May 28, 2026, 08:12:15 AM
Beamfinder feature [SOLVED]
Started by Breitling, November 02, 2013, 03:58:20 PM
Breitling
#15
Solved. The issue was related to the installation path (c:\Program Files, W7). Reinstalled on a different path it works perfect. Thank you all for your support.
satcom
Brilliant...and apologies , I should have noticed that path through programmes
We always recommend everything is put straight onto a folder on C drive unless running XP.
fidaeextra
Hello to all'
Breitling, the  only beam that see, was the beam of your first location in your radar.txt file?
I have the same problem and my planeplotter is install too in the program files location.  i need re-install I think so
Breitling
Quote from: fidaeextra on November 06, 2013, 11:11:52 AM
No fidaeextra, you can see any radar beam from any valid line on the radar.txt file. All lines not begining with a semicolon ("punto y coma ; "). Obviously they need to be radars on your area.
