November 26, 2026, 03:39:26 PM
SBS-1 Unable to open database file
Started by ColR, March 17, 2012, 01:07:54 PM
G4UMW
In SQLite Expert you can also run Vacuum and Integrity Check by clicking on the appropriate icons on the toolbar without having to type the SQL statements.
Rob/G4UMW
Thanks Rob, I've learnt something new (again).
ColR
I will try that asap and report back and also not using planeplotter or anything else i am aware of.
ColR
All SQL checks OK
Opened Basestation and got the same error message straight away.
What version of Windows are you running?
ColR
Thanks.  Did you run the checks on the Basestation.sqb file in Program Files or the one in  the Virtual Store, assuming you installed Basestation to a default location?
ColR
Hi I did the checks on a copy of the sqb file obtained from C:\kinetic\basestation folder
Do you know how to find the Virtual Store?  That's where the "real" sqb file is lurking and the one on which to run the integrity checks.
ColR
OK, go to My Computer and the select Tools->Folder Options.
Then select View tab and then scroll down and select "Show Hidden Files and Folders" and uncheck "Hide Extensions for Known File Types" and "Hide Protected Operating System Files (Recommended)".
OK the changes.
Then select Folders and look for the Users folder and then your logged in user name.
Select this and you should see a App Data->Local->Virtual Store where there should be a Program Files->Kinetic->Basestation folder.  If you have 64 bit Windows it should be Program Files(X86).
If you can see the active Basestation.sqb file in the Virtual Store location, run the checks on that.  This file should be much bigger than the one you checked before.
ColR
Found it do i take a copy of this place on the desktop and run checks from there ?
Yes, same as before take a copy and run the checks on that to see what you get,
ColR
Can you close Basestation then rename the sqb file in the Virtual Store location (basestation.sqb.old).  Then restart Basestaion which will open a new, empty sqb file.  Let is run for a while to see if you get the same error message?
