August 24, 2026, 07:33:44 AM
Quote from: w4lron on April 13, 2017, 07:15:41 PM
Add filtre N-XXXX showing no data..This was not the way it used to be
The radar ID is now meaningless.  There have been many posts on the FR24 forum about this.
If you want to see your radar ID on the FR24 website or app, it's like looking for a needle in a haystack.  Sometimes there's no needle.
As long as your account shows Online and you have the Business account, that's what really matters.
terrywadeairbus
Is there an issue with the SBS-1 Client?
The past two days I've been unable to connect to it?
Terry Wade
paulm
Its been the same here,
No aircraft showing on MM2 web interface either.
Paul
Rather than post on the forum, why not send me a PM?
It will get actioned quicker.
I've emailed Piotr to see if there's an issue he can fix.
However, I should warn all sharers that this service may be withdrawn at any time.  FR24 now has no interest in data shared from BaseStation.
Should be OK now.
Please retry.
terrywadeairbus
Thanks Amner it's working OK now.
I'll PM in future, but I thought that was the purpose of the forum seeing
if anyone else had issues and it wasn't unique to me.
Terry
Quote from: terrywadeairbus on June 18, 2019, 11:29:46 AM
If you send me a PM I can quickly check if there's an issue affecting others,
paulm
MMS2 is not working again most of yesterday, no aircraft showing on MM2 web interface either.
Paul
Thanks.  I've emailed FR24.
paulm
Thanks Mike working again now.
Paul
paulm
MMS2 is not working again, MMS2 Web Interface is not showing the feeders illuminated the way it did when it failed previously, is this the end ?
Paul
I'll have to check again with FR24.
paulm
Working again now at 8.42 just a glitch then.
Paul
sterigia
once fixed my issue i wold like to join in as my main display to is bs and not pp.
if ti's still in use post me instructions please
thanks
frank.
no more free meals for radarbox or radarbox24. rb turned on without antenna permanently
