August 28, 2026, 03:01:42 AM
bad signal
Started by Radio2.0, December 20, 2014, 11:52:40 PM
Radio2.0
Hey
I use an 1090 Yagi Antenna. Before my dad attached the new Antenna (and turn the Mast a little) the Signal decreased.
RTL1090 show me THR: -72db [19]
What does it mean?!
What could happened to my Antenna that the Signal dropped so much?
Thx
G4UMW
#1
THR shows the average noise level, not the signal level. It's all explained in the RTL1090 documentation.
Rob/G4UMW
Radio2.0
So which Number is better 19 or 8 ?!
Sorry the documentation is worst for RTL1090.
G4UMW
#3
The 19 is the absolute hex equivalent of -72 so effectively they are the same thing. What was your db figure before?
Rob/G4UMW
Radio2.0
sorry i dont understand anything in the "Radio Language".
Is the value good or bad?
G4UMW
See my previous question - what was the db figure before?
Rob/G4UMW
Radio2.0
G4UMW
The -79 db figure appears better as it implies less noise.
Rob/G4UMW
Radio2.0
That means the noise level on the dongle with LNA is much higher?
G4UMW
Yes. You may well be overloading your dongle with the signal from your amplifier. This could appear as noise to the  RTL1090  software. An article in a UK radio magazine this month also described signal overload of a dongle when using a preamp.
Rob/G4UMW
Radio2.0
Is there an way to see the Signal Quality?
I know the software is a beta... (I fond no way to use some other SDR 1090 Application wo support more than one SDR Dongle. In RTL1090 i use one as an master and the other send there UDP Data.)
G4UMW
Not as far as I know.
The problem is that both your dongle and the preamp are wide-band devices. Anything your antenna collects will be amplified, not just the wanted signal.
A preamp should only have enough gain to overcome the signal loss in the feeder between antenna and receiver. It is NOT designed to function as a substitute for a poor or badly-sited antenna.
Rob/G4UMW
