May 28, 2026, 10:39:23 PM
PP port forwarding help
Started by globemaster27, November 10, 2014, 05:13:40 PM
Quote from: Keef on November 11, 2014, 10:30:48 AM
I don't see this as hijacking a post, I see it as an offer of help and I don't have a problem with satcom withholding details of development work.
And I don't see why Satcom can't share the solution with other Radarspotting members who may have a similar problem.
Perhaps a more helpful response would have been:
"Sure Mike, as soon as we have a fully tested solution I'll be only too happy to share it with the Radarspotting members.  Just need to run some more tests."
All I asked was for the solution to be shared here. I didn't put a timescale on it,  just wanted others to benefit and ensure thread continuity.
globemaster27
Yes i have configured PP to be allowed trhough the firewall.. altough that bat file which enables this stuff comes up with an error..
My sharecode is:hi
it should be possible trhough a VPN..
globemaster27
BTW i am more then happy to receive help through teamviewer...
This is getting tiring, as i have purchased a nie antenna that i really want to share to get mlatting going in scandinavia :)
Have you sent a PM to Satcom as he suggested in an earlier post?
shakysen
Hi just a thought.In the distant past I encountered a Problem with PP .on checking I had 3 firewalls running WIN,AVG,AN ROUTER
globemaster27
Yes i have. anmer
Maybe i shouldnt have? After reading the reactions...
Quote from: globemaster27 on November 11, 2014, 05:30:45 PM
No problem sending him the PM.  I just want to be sure that any solution is posted here so others can benefit.
globemaster27
I will sure do that! i hope i am not the only one having this issue, so i would love to help others.
globemaster27
UPDATE:
Soooo, it was too much a hassle with the VPN.. So i just took the direct route to
the ISP, and asked if they could open the port.
They could not, however they could give me a very own IP adress, that would allow port forwarding.
They gave me my own IP adress, and now i am up and running.
For anyone also having issues like this i greatly advice that they should chech if they run through multiple routers.
Thnaks
Thanks for the update and good to know you found a solution.
