May 19, 2024, 03:00:00 PM
BS Acft dets window problem after last MS update to Win7
Started by Truetrack, March 23, 2015, 10:36:11 AM
Truetrack
After last MS autom update for Win7 home premium
I could not open Aircraft Details window in a running BS (.168) by double left click in column of aircraftlist
as i usually do when adding dets rightaway.
Aircraft details (no response) and blank.
1st thaught SQB corrupt - renamed activ (in virtual store) and replaced by a previous.
Again BS loading/running initinally normal    but then same queer behaviour when trying to edit.
So it was not the suspected corrupted SQB.
Then resetted the PC to a point prior to last evening's update.
Now everything including editing work fine again.
Anyone else had this issue ?
What to do if MS auto update again ?
Klaus
I have an issue that I cannot open links by clicking on them.
I have the same issue since the weekend using Win 7.
G4UMW
All OK here, Win 7 64-bit with all applicable updates installed.
Rob/G4UMW
Quote from: G4UMW on March 23, 2015, 12:12:44 PM
Hi Rob, what is your default browser?
G4UMW
Rob/G4UMW
Thanks Rob.
I'm running BaseStation 1.2.4.184 and whenever I select an aircraft from either the map or aircraft list I get a popup File Download message, as attached.
Running Windows 7 Pro 64 bit with latest downloads installed today.
My default browser is Chrome but, from memory, BaseStation invokes IE.
Truetrack
Hi Mike
could it possibly be that this just one file is now missing for some reason, possibly in virtual ...userdata ?.
Thats where mine temp1 and temp2 are and they are rewritten rightaway whenever I amend a Aircraft
detail window.
Klaus
The BaseStation files are in a folder I created which avoids the Virtual Store.
The XML files are where they should be.
I will do some experimentation at the weekend as I'm away tomorrow.
