November 16, 2026, 10:51:11 PM
UK & Ireland MLAT Project
Started by Mutt08, June 28, 2015, 12:38:54 PM
MrParanoia
Quote from: IanH on July 02, 2015, 12:29:45 PM
It's not going to replace PP as my main display since that shows all plots. And I would need yet another monitor to display the MLAT Radar! But a useful option to run in the background and occasionally check what else is out there and not being shown by PP.
I joined up this morning and have to say I am quite impressed - your MLAT data is returned so I have piped this through ModeSmixer2 and now have MLAT plots showing alongside regular plots in Basestation :)
To save me having to figure it out, what commands did you use to pipe into BaseStation?
MrParanoia
Quote from: IanH on September 15, 2015, 10:56:39 AM
ModeSDeco2 to Basestation and the MLAT server: --sbs10001 10001 --beast 30005
ModeSMixer2: --inConnect 127.0.0.1:30005 --inConnect 127.0.0.1:31000 --outServer sbs10001:10002
Basestation: Settings - Hardware Settings - Network Tab - Port 10002
I've left the --sbs10001 10001 command in the ModeSDeco2 bat file so the data can be fed elsewhere if I require, however I guess removing that parameter would negate changing the port within the BaseSatation software.
If you get an error when starting ModeSMixer2, just close down BaseStation before starting ModeSMixer2
Thanks, I'll give that a try later.
Tried it and I can get it to work.
BUT do not connect this type of setup to a PlanePlotter feed.
It will feed both the local data from the receiver AND the MLAT data from the MLAT server.
Probably explains what people have seen and reported on another thread.
Quote from: IanH on September 15, 2015, 06:42:43 PM
We had the same issue with SBS1Client.  Piotr added a PP feed option to avoid it.
Radio2.0
is there any Standalone Mlat Server out there?
Im my Area are some ADSB sharer who i know.
