November 21, 2026, 08:03:20 AM
Tinkering with your Dongle setup
Started by Bethsalem, September 04, 2015, 12:36:03 PM
Bethsalem
Quote from: IanH on September 27, 2015, 12:01:17 PM
QuoteAlso FlightAware are offering a new 1090MHz bandpass filter
RTL-SDR dongle has arrived - took about 3 weeks to get here. Already have the CosyCave LNA.
Where on the Flightaware site does it mention 1090 filters for sale?
It's from here Ian, http://www.rtl-sdr.com/new-product-from-flightaware-a-1090-mhz-bandpass-filter-for-the-rtl-sdr/
Doing a search for alternatives, I found this:
http://ava.upuaut.net/store/index.php?route=product/product&product_id=85
LNA plus filter in an aluminium case (looks like a PlaneGadget Radar!). £36 plus £5 postage.
Which way to go?
Bethsalem
Quote from: Bethsalem on September 04, 2015, 12:36:03 PM
I just can't leave well alone...
I've attached a picture of my current dongle setup. By attaching an LNA and LTCC 1090MHz filter just in front of this newly revised version of the venerable R820 dongle I have more than doubled my frame-rate, and much more importantly, the number of aircraft on my screen.
For example, using the dongle alone I'm seeing 225 frames per second and 35 aircraft on screen.
With the LNA and filter I'm seeing 550 frames per second and 55 aircraft on screen.  :)
The total cost of this setup, new dongle, LNA, tablet charger, connectors, boxes and filter, but excluding antenna, coaxial cable and laptop, was about 75 euros including total postage.
Not a bad expenditure for the increase in sensitivity which now rivals my Beast setup, which cost considerably more.
Just over a year later and I've updated my setup thus (have a look at the attached photo)
The new step us consists of > Antenna - FM Band Stop Filter - LNA - 1090MHz Band Pass Filter - Prostick(LNA plus R820T2 dongle combo)
I'm getting roughly 10% more reported positions according to my PiAware stats page.
I've attached a couple of screenshots showing how this new dongle setup (Reus889) is outperforming my Beast (Reus890), 67 aircraft (dongle) versus 47 aircraft (beast) which is quite a remarkable feat, I think.
Thanks for sharing.
How long is your coax?
And what WiFi USB device is that?
And what happens if you remove the filters and amp?
Bethsalem
Unfortunately the coax cable is 17 metres in length.
The WiFi USB device is the official Raspberry Pi WiFi dongle.
If I remove the FM band stop filter and the first LNA, then the aircraft seen dips to about 20% below Beast value. So for illustration sake, if the Beast is showing 50 aircraft, the Dongle, sans first filter and first LNA, is showing 40 aircraft.
If I return the setup back to normal R820T dongle, plus 1090MHz band pass filter, plus powered LNA, then I'm seeing about 10% more aircraft than the Beast, so for illustration sake 55 aircraft (Dongle) versus 50 aircraft (Beast).
I've experimented with every possible configuration, and this setup with two filters and two LNAs, in the sequence I've set them up in, works the best by far, consistently out performing the Beast.
Radio2.0
Bethsalem
No, because I've attached the 1090MHz band pass filter immediately in front of the ProStick, and in this configuration FlightAware say that you can leave the gain on automatic.
I have messed around with changing the gain just out of curiosity, but the results were always worse than when I left the gain setting on its default setting.
Bethsalem
I've been using the new setup since last Friday evening (21st Oct) and I've noticed the greatly increased number of positions reported. I'm not seeing many extra aircraft, but the ones I do I'm seeing for longer. The range I can detect out to has only increased slightly, but the signal strength is stronger.
Stats courtesy of FlightAware.
That's typically what I experience with an amp.  Similar range with more contacts for longer.
Your setup is working well.
Bethsalem
I'd read on one of the Reddit subforums that using a "two amps, two filters" system was increasing the likelihood of receiving a usable signal for Outernet and for Inmarsat, so I thought I'd give it a go for ADS-B.
It certainly is an improvement on my previous setup, but only if I link the components together in the way I have
FM bandstop filter, LNA, 1090MHz bandpass filter, finally ProStick (LNA + R820T2).
No other combination gives the same result.
