November 10, 2026, 12:12:06 PM
AirNav Comstation Teardown
Started by GregoryGHarding, September 13, 2015, 08:08:55 AM
junglejet
Gregory,
can you post a closer-in photo of the RF part of the upper PCB, too, please?
This is the area just behind the SMA connector.
It seems there are no SAW filters in this area and the whole setup reminds me of this small silver box that was on the market for some time, but disappeared 3 years ago or so, which name I forgot (but Anmer will remember)
Andy
Quote from: junglejet on September 14, 2015, 12:08:07 PM
Hi Andy
Do you mean the PlaneGadget?
http://radarspotting.com/forum/index.php/topic,320.msg1823.html#msg1823
tarbat
Quote from: GregoryGHarding on September 13, 2015, 08:08:55 AMi've connected up the USB and installed some serial drivers, i can connect to the box but it just repeats its product name and serial number.
Might be worth trying the Radarbox software, and see if it detects the CommStation.
http://www.airnavsystems.com/Radarbox/support.html
tarbat
Quote from: Anmer on September 13, 2015, 08:41:06 AMThe absence of an HDMI interface and SD card slot could prove a bit of a challenge to diagnose issues and upgrade firmware/software.
Previous Airnav hardware - ShipTrax - updated firmware via. the USB/serial interface.
Quote from: tarbat on September 14, 2015, 03:06:36 PM
And we all know how well that sold!
But seriously, is installing the software on a board component a good idea?
tarbat
Quote from: Anmer on September 14, 2015, 03:16:55 PMBut seriously, is installing the software on a board component a good idea?
It probably is if the vendor is more interested in keeping the firmware secure.
Quote from: tarbat on September 14, 2015, 03:25:14 PM
Depends on the component's reliability.  Time will tell, assuming the CommStation gets installed in sufficient numbers to measure field performance.
Interesting that Pi and Beaglebone alternatives use SD cards.
GregoryGHarding
Quote from: tarbat on September 14, 2015, 03:02:35 PM
That was the obvious route, I never write that in my original posting because I thought that was the given
GregoryGHarding
Gregory,
Andy
It's back together now. But give me a few hours and il see what I can do
junglejet
Exactly, Mike.
Mmm, seems I am getting old ...  ???
Quote from: Anmer on September 14, 2015, 12:13:57 PM
Hi Andy
GregoryGHarding
They seem to be all about security. This is the first company I've encountered  that asks you to host equipment for them using your resources and doesn't even let you access the raw feed. I was directed to radarbox24.com after emailing them telling them I cannot access data via regular ports or serial.
Quote from: GregoryGHarding on September 14, 2015, 06:41:35 PM
In the 8 years I've had dealings with AirNav Systems (aka Andre Brandao), "paranoid" is the word that first springs to mind.
If Brandao had spent more time on understanding business and what makes for success instead of telling everyone that he's the biggest and best, claims that were easily shot down, he wouldn't have been surpassed by the likes of Kinetic, Flightradar24 and FlightAware.
Hosts invest time, electricity, bandwidth and cash (erecting the obligatory external antenna) and justifiably expect something in return.  AirNav always wants everything for nothing and even helps itself to RadarBox owners bandwidth without their expressed permission.
One to avoid.
Quote from: junglejet on September 14, 2015, 06:40:25 PM
You sure are, along with everyone else here.  ???
GregoryGHarding
Quote from: Anmer on September 14, 2015, 07:03:26 PM
One to avoid.
This benefit to me is the antenna, I have parts in post to build my own splitter,then gonna run the rbcs, and a few dongles for modes, acars etc
