May 03, 2026, 05:41:10 AM
KMCO
Started by sdlangford, November 14, 2015, 04:16:20 PM
sdlangford
Can anybody point me in the right direction for an outline of Orlando KMCO airport please.
Simon
Truetrack
Have a look at  Rod Bearden's
http://www.rodbearden.com/RadarBox/Downloads.htm
and download the Outlines collection, amongst others you will find KMCO and more US fields.
Though originally intended for Radarbox, these files work in BS as well.
If interested in Final APP paths ect. you will find Acarslogger's splendid files
in eg. Active Display Lite > Pulldown BS config > Install outlines/waypoints
there are many of Florida listed.
FYI ADLite can be downloaded from
http://www.gatwickaviationsociety.org.uk/ADL_home.asp
then  free register
Klaus
I see you've also posted on the "dark side" and reporting an error loading the outline from Active Display.
What error are you getting?
acarslogger
There's a typo in the KMCO outline. You can modify the outline file; see http://radarspotting.com/forum/index.php/topic,4787.msg22429.html#msg22429 .
Stuart
Truetrack
On this hint by Stuart I looked at the KMCO file.
Usual mistakes when editing are eg.comma for decimal point v.s.
or incorr closing a line not closing by  -1
or incomplete remark brackets
And here it seems to be in the very beginning
1st line either add the bracket with any text editor,
or delete this first line .
Hope it will load then.
Klaus
acarslogger
QuoteAnd here it seems to be in the very beginning
Do not delete the first line. Add an open curley bracket as per my instructions in the linked post.
Give credit where credit is due.
Stuart
Truetrack
On second thought, Stuart you are right .
I agree with that
Klaus
