September 21, 2026, 01:17:57 PM
SBS-3 Firmware Update
Started by mhm, April 22, 2012, 10:49:49 PM
Roadrunner
I also think the name of the older file SBS3FirmwareUploader.exe is much easier to associate with the job it does than the ProgUsbLattice.exe supplied this time.
Quote from: Roadrunner on April 26, 2012, 07:19:04 AM
So do I.  But it's Kinetic that we have to convince.
Chris-G0WTZ
Updating Software and firmware
To update Basestation to the latest version down load the latest exe file from the support area of our website! Extract (Unzip) the file and note where it is.
On your desktop go to the Basestation shortcut and right click on it. Select the option to open in containing folder
That opens your Basestation folder
Then go to  the unzipped Basestation file right click on it and select copy then go to your open basestation folder and paste the new file in it.
You will then run the new version when you click on the short cut.
To Update the firmware down load the latest firmware for your device and the relevant firmware loader. Copy them both into the same folder and right click on the KFF file. Select open with and point it to the Firmware loader. A dos box will pop up and you will get rows of dots and characters.
When finished the box will close
The SBS-3 can take up to 5 minutes and the SBS-1 series 2 or 3 minutes.
The latest firmware for the SBS-3 gives decoded AIS on an NMEA data stream which at this time is only available when connected by Ethernet
Please read the release notes to set up the SBS-3 for this function
When running the SBS-3 on ethernet with AIS ADSB and radios running you need a good power supply. All our tests are conducted with an Ipad 10w Power supply which works fine
kdt1
#18
"SBS-1 series 2 or 3 minutes"
Isn't this Update just for the SBS3, Thanks
Quote from: kdt1 on April 27, 2012, 04:06:48 AM
The procedure is the same, the files are different.
kdt1
