May 30, 2026, 08:34:41 PM
ACARSD/SBS Querey
Started by phat01, June 04, 2016, 06:12:44 PM
phat01
exhausted my abilities aswell....... app crash grr
attached a pic of it..... i hope lol....
on a side note how do you set up modesmixer2? as i would like to use that to run with Virtual radar and hopefully feed the basestation software.....
There's some info on MM2 and VRS here:
http://radarspotting.com/forum/index.php/topic,4054.msg26176.html#msg26176
That might help you. I don't use VRS so can't advise on parameters for that. My use of MM2 is detailed in the first post in the thread above.
Your screen grab didn't show much apart from a Team viewer error message.
phat01
ha epic fail with that one......
thanks for the link will have a go tomorrw  ;D
phil
phat01
well i copied what i needed to do and the app crashed:
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   modesmixer2.exe
  Application Version:   0.0.0.0
  Application Timestamp:   5741ab8c
  Fault Module Name:   modesmixer2.exe
  Fault Module Version:   0.0.0.0
  Fault Module Timestamp:   5741ab8c
  Exception Code:   c000001d
  Exception Offset:   00053e5c
  OS Version:   6.1.7601.2.1.0.768.3
  Locale ID:   2057
  Additional Information 1:   0a9e
  Additional Information 2:   0a9e372d3b4ad19135b953a78882e789
  Additional Information 3:   0a9e
  Additional Information 4:   0a9e372d3b4ad19135b953a78882e78
its odd that its the same as the others grr
Phil
