May 02, 2024, 01:55:03 PM
Logos required
Started by BLACKHAWK101, July 30, 2016, 09:20:59 AM
BLACKHAWK101
Hi Paul
Hope you are well, when you have time can you please do the following.
WOW                    A21N                              Generic as TF-SKY
CSN                      A21N                              Generic as B-8367
KZR                     A21N                               Generic as P4-KDC
ALK                      A21N                              Generic as 4R-ANC
Many thanks
Steve Coulson
paulm
Steve
Your latest requests posted in the usual place
Paul
BLACKHAWK101
Hi Paul
Many thanks for the logos look great as always.
Steve Coulson
BLACKHAWK101
Hi Paul
As the 737 MAX is starting to get going with deliverys to 2 or 3 airlines taking place can you please do the following LOGOS,
IBK                        B38M                            Generic as EI-FYA/FYB
WJA                       B38M                            Generic as C-FRAX
SWA                      B38M                            Generic as N8711Q
BTK                       B38M                            Generic as PK-LGJ
MXD                      B38M                            Generic as 9M-LRC
NVD                       A21N                            Generic as SE-RKA
Many thanks
Steve Coulson
paulm
Steve
Paul has also asked for the Norwegian IBK B38M so I have been thinking about what's possible.
The lettering on the aircraft shows BOEING B737 MAX 8, B737 is what would normally be entered on the logo due to space constraints.
If I where to reduce this to B737MAX8 it would more than double the width, the M is 5 characters wide instead of 3, in a large amount of cases this simply wouldn't fit.
I was thinking of B738M or maybe B737M8, I would value your opinion.
I attach a couple of samples based on the IBKb38m you can see the problem.
Paul
BLACKHAWK101
Hi Paul
From a personal prospective i like the b738M and b737M b739M for the other models with the ICAO code with the airline code ie, IBKb38M.
This is of course my choice but others may have different opinions but i will be happy what ever you choose to do.
Many thanks
Steve Coulson
paulm
Steve
Your latest requests posted in the usual place.
Paul
BLACKHAWK101
Hi Paul
Thank you very much for the last lot of logos, can you please do the following,
HXA         A320              Generic as B-8697
SBI          A20N              Generic as VQ-BCF
TRK         A319               As TC-IST                       Turkish govenment
MMA        A319              Generick as XY-AGU
                A319              As HL8080                       SK Telecomm
CGA        A320               Generic as 9S-ALU
LAO         A320               Generic as RDPL-34188
JCC         A320               Generic as XU-997
SAW        A320               Generic as YK-BAA
HTU         A320               Generic as B-8432
Many thanks
Steve Coulson
paulm
Steve
Paul
BLACKHAWK101
Hi Paul
Many thanks for the logos , fantastic as always and thank you for the time and effort that you put in.
Steve Coulson
BLACKHAWK101
Hi Paul
Can you please do the following logos when you have time,
TGW (SCOOT C/S)      A320                   Generic as 9V-TAZ
Flyadeal                       A320                    Generic as D-AXAC (will become HZ-FAA)
LNI                              B38M                   Generic as PK-LQJ
FDB                             B38M                   Generic as A6-MAX
Many thanks
Steve Coulson
paulm
Steve
Paul
BLACKHAWK101
Hi Paul
When you have time can you please do the following LOGOS,
ANA                              A21N                          Generic as JA131N
AVA                              A21N                          Generic as N761AV
GCR                             A20N                           Generic as B-8952
CSC                             A20N                           Generic as B-8949
AMR                              B38M                          Generic as N324RA
SLK                               B38M                          Generic as 9V-MBA
QFA                               B789                           Generic as VH-ZNA
Many thanks
Steve Coulson
paulm
Steve
AMR ?
Paul
BLACKHAWK101
Hi Paul
Many thanks for the last lot of logos.
Could you please do the following when you have time,
MAU    A359            Generic as 3B-NBP
HAL     A21N            Generic as N202HA
Many thanks
Steve Coulson
