September 23, 2026, 08:41:42 PM
Flight Air Map - Web App
Started by mezoo, November 12, 2016, 04:55:37 PM
Breitling
Quote from: IanH on November 15, 2016, 09:32:32 AM
Looking at those error messages, did you enter values for all the latitude and longitude data?
As I recall there is a Max and Min required for each.
Also for the centre of your coverage (home?) and for the location of the receiver.
Yes, I'll double check it now but I'm pretty sure they all are set. For the default map view and for each of the sources.
I think you are correct - your home location is in Northern Spain on the map and zooming out your target area appears as a pale blue box.
Made me realise mine was wrong. I needed to add minus sign to my western longitude  :-[
Although it ran without an error previously.
Breitling
I've made a minor change in settings.php:
//DAEMON
$globalDaemon = FALSE; // Run cron-sbs.php as daemon (don't work well if source is a real SBS1 device
It was originally set to TRUE, so I tried and now I have the attached output in daemon-spotter.php
Anyway, cron-sbs.php is exactly daemon-spotter.php  ¿??¿¿?
Running out of ideas....
just stopped and restarted mine.
It says "Connection in progress to 192.168.207:30003 <sbs>"
Try setting the format to sbs instead of raw or auto
And I found that I needed
$globalDaemon = TRUE; to run daemon-spotter.php
Breitling
No way, sbs mode for the FR24 box throws garbage everywhere, reconnecting every few seconds.
Now I have only one source: S-Beast serving raw data through PlanePlotter TCP/IP server output (port 30003). It connects Ok but still the same error.
The almost inexistent project documentation does not help a lot.....
Port 30334 on FR24 is beast format, that is not yet supported.
Port 30003 us also available on FR24 box to output sbs
You have to read the scripts to figure all this out  :'(
Breitling
Quote from: IanH on November 15, 2016, 11:23:36 AM
Done !!!    Just a single source now, FR24 box in SBS format on port 30003.
Let's see if I can add now some other sources I have access to.
Thanks so much Ian !!
Try using modesmixer2.
I'm currently plotting the combined output from Piaware ADSB and MLAT into my local FlightAirMap.
That is beast format so a quick
c:\radar\modesmixer2.exe --inConnect 192.168.0.177:30005 --outServer msg:30003
takes the beast data from a Pi and sends out SBS format data. Use that input into FAM
mezoo
Breitling,
your site is looking well.
Yesterday I learnt that you have to run the update-db.php script to update the stats.
I still have problems with the countries.
The db just contains 23 countries and FAM stats insists that all flights pass over Algeria ;-)
I'll contact Ysurac to ask for help on that.
It also seems to me that if you continue going deeper into the stats things go wrong.
e.g. when I search for all Dreamliners everything seams reasonable until I arrive at airports.
Then the Dreamliners are landing at all local airports in Europe but not in Frankfurt or London.
mezoo
I just saw that Ysurac has made a fork or special version of dump1090_mutability.
It is however in C code, so you have to compile it yourself.
Not sure if it is still being updated.
As I dont have a compiler I cant test it.
https://github.com/mutability/dump1090
Breitling
Quote from: mezoo on November 15, 2016, 09:00:08 PM
Yes, I set up to run it hourly with the task manager, so I have METARs updated.
mt007
Quote from: mezoo on November 15, 2016, 09:33:13 PM
Mezoo
there are some screenshots from this special version we can see?
Best regards.
Miguel
Miguel Teixeira
Beast user, Ex: SBS1er and RB, PP sharer aH Live Traffic
mezoo
Not from me, as I am not using it.
All I know is from the Github listing.
Sorry.
#28
Cancel previous message - found the fork now!
mezoo
#29
Has anybody managed to setup the use of local photos.
The way I understand it is that you have to setup use the of customsources in the settings.php as follows:
// *** Aircraft pics ***
//Retrieve Image from externals sources
$globalAircraftImageFetch = TRUE;
//Sources for Aircraft image
$globalAircraftImageSources = array('customsources','ivaomtl','wikimedia','airportdata','flickr','jetphotos','planepictures','planespotters');
// Custom source configuration {registration} will be replaced by aircraft registration (exif get copyright from exif data for each pic)
// example of config : $globalAircraftImageCustomSources = array('thumbnail' => 'http://pics.myurl.com/thumbnail/{registration}.jpg','original' => 'http://myurl/original/{registration}.jpg','source_website' => 'https://www.myurl.com', 'source' => 'customsite', 'exif' => true);
$globalAircraftImageCustomSources = array('thumbnail' => 'http://192.xxx.yyy.zz/Website/Photo/{registration}.jpg','original' => 'http://192.xxx.yyy.zz/Website/Photo/{registration}.jpg','source_website' => 'http://192.xxx.yyy.zz/Website/Photo/{registration}.jpg', 'source' => 'localhost', 'exif' => FALSE);
Unfortunatetly this does not work.
I deleted all links in the spotter_image db but after some hours it was full of external links again.
Then I changed some links in the db manually - which worked.
Any ideas ?
I will remove the external links and experiment a bit with different path settings.
