April 18, 2024, 10:36:07 AM
How best to implement Basestation on Win10/64 ?
Started by Truetrack, November 16, 2016, 03:55:39 PM
Truetrack
I once read about it all , but as times go by.....
I want to implement BS for SBS-3 to newer PC with Win10 Home (64bit)
Presently running on Win7 and still happy with it
BS 1.2.3.168
Firmware SBS-3 Build 113
(after initial tests never used the SDR-Function because of the limited Bandspread of each Tuner, so no need for newer)
My question now
what is the easiest way to implement BS in Win10 , and then preferably
the latest Versions BS and Firmware ?
And what to avoid in the first place with Win 10/64 ?
Virtual store is no problem ... being now used to it.
As download I have seen:
Firmware xxxx_0119_R_SBS3.kff
progUSBLattice.exe
BS 1-2-4-184-exe-only
BS-1-2-4-184-CDROM
Any difficulties with missing drivers or DLL to expect ?
What is the easiest way to do it then ?
Your helping info from your own experience is much appreciated here.
TIA
Klaus
Klaus
I upgraded to a win 10 64 bit machine
I downloaded from kinetic site the basestation software and let it install itself without changing anything.
As you are aware of the virtual store, no need to go into detail.
You should have no problems with the installation. You will have to put in your location as normal.
Don't forget to take a copy of you sqb to replace the new installed one on you new pc.any probs give me a call
mhm has covered most things.
Download the CD file and install from that.
You may not need the new firmware.  If you do:
http://radarspotting.com/forum/index.php/topic,599.msg3066.html#msg3066
Personally I'd install outside of the Virtual Store and copy your existing files to the new location.  But it's your choice.
You may need to use the CDM20814_Setup file to force install the USB drivers.  But you may be using Ethernet?
And you may get a missing ftd2xx.dll message.  But you should have that on the old PC.
Post back here if you need any help.
Truetrack
Thanks for that quick response. Mike & Mike make a marvellous Team .
and for pointing me to the steps for Fw uploader
Shall observe your suggestions.
Since keeping the W7 Unit shall start with updating this one with Fw/Sw.
W10 comes next after setting up all the personal progs there.
Takes some time though, shall let you know how things fared then.
Klaus
Truetrack
Glad that I updated Firmware within existing Win7 system
Now getting aquainted with Win10 shocked by the differences.
Connected SBS3 build 119 and downloaded and installed BS ex ...CD-ROM as suggested.
OK and the still virgin BS is running
So far so good, could customize and fill in Outlines + WPTs.
But then I had problems accessing the Virtual store, and when trying to copy
the pathes vanished again. Finally got my files into it.
Oh boy how I miss my 'beloved' Win7 .
Now BS is working in my way as well as the BS-Reporter recalling proper SQB.
new SQL-Browser comes next.
Klaus
Glad your up and running. my pc just died now at pc doctor
BLACKHAWK101
Evening gents
Just had to change to a new LAPTOP and i am having trouble getting Basestation to work on WIN 10.
I have down loaded from the Kinetic site a new install and after the ftd2xx.dll problems i am left with the following,
The procedure entry point FT_EE_Program could not be located in the dynamic link library C:\basestation.exe
Any Help most apprecated
Steve Coulson
BLACKHAWK101
Hi Mike
I have tried both and have tried letting it install to the default location and then had another go installing to C:\basestation both come up with the same thing.
Thanks for your help
steve Coulson
Are you unzipping the file before doing the install?
