June 25, 2026, 03:22:37 AM
Feeding Radarbox with pro stick
Started by thedouth, August 10, 2017, 05:54:58 PM
thedouth
Do I just need to install zadig drivers to use a pro stick to feed radarbox or do I need to do anything else
You will need the Zadig drivers if you're using Windows.  This will handle the Pro Stick.
You will also need the RadarBox software to process the data.
I think you've already posted on the AirNav forum about this?
https://www.airnavsystems.com/forum/index.php?topic=10401.msg199251#msg199251
