October 14, 2026, 06:22:47 PM
Homebrew aerial
Started by yarmouthshipping, May 06, 2012, 02:44:55 AM
JohnOCFII
Thanks Shaky!
I noodled around and also found the following useful information:
There are two sections at the page below discussing antennas, including a photo of his attempt at a ground plane antenna for ADS-B:
http://www.sprut.de/electronic/pic/projekte/adsb/adsb_en.html
I also found detailed instructions for a similar ground plane ADS-B antenna linked from here under "Your first ADSB Antenna":
http://www.atouk.com/wordpress/?page_id=237
John
Saudistu
Quote from: dongle on October 26, 2012, 04:40:07 PM
You can make a pre-amp for about £4.
Take care how you feed in the power to it and make sure you provide a capacitor of maybe 100pf between the collector of the transistor and the input line to your receiver, else you won't do the RX any good at all.
Here is a really cheap one:
http://www.lll.lu/~edward/edward/adsb/preamp/ADSBpremap.html
If anyone has had a go at making and using one of these can they please post the results, as in does it give a noticeable increase in range ? Thanks for any help.
