November 23, 2026, 12:13:46 PM
Basestation gone memory crazy
Started by Saudistu, February 20, 2017, 11:05:21 AM
Quote from: Saudistu on February 28, 2017, 09:59:49 AM
I only use the FR24Feed softwareasI believe you have to use this to get the Business account, otherwise I would just add it to the Planeplotter Sharing output which I also use to feed Flightaware.
Why not see what happens?  If you feed FlightAware via PlanePlotter you get a free Enterprise account.  Maybe FR24 operates the same way?
Saudistu
Hi Mike,
I read that FR24 does not give out Business accounts to Feeds from  Planeplotter. Although this may have changed, I can find no information to say that this is so.
As an aside, having read the FR24Feed instructions it talks about other ports and using Basestation. For me, the problem has only started since using the new FR24Feed.exe as I still used an older version before which unfortunately is no longer available for download. The document talks about port 10001 and 20072, but I thought SBS-3 output on 30003 to Basestation and 30006 for say Planeplotter ? Just wish I still had the older feed software !
