September 23, 2026, 02:43:01 AM
FR24 Feed Software
Started by Saudistu, March 04, 2017, 11:23:19 AM
Saudistu
Hi Mike. The .zip file came through. Thanks for that. I will give it a try later and let you know the outcome.
Regds....Stu
Saudistu
I have installed the Feed software provided by Mike. It is indeed the same software that I previously used. All I had to do was enter my sharing key and press start. No messing about with choose this/that option in a dos window.
I am a great believer in "if it ain't broke, don't fix it". In my opinion FR24 just complicated things with the newer software version. It also uses more resources and on my system it definitely caused Basestation problems.
So, I am now running the old software, Basestation and Planeplotter are both running smoothly and my data feed is showing online in FR24. Importantly, Basestation is sat quite happily at about 40Mb system RAM usage and is not increasing.
Thanks Mike for the software, and everyone else for the suggestions. It is really appreciated. Now I can watch the Football without checking the computer every five minutes !
