September 15, 2026, 09:31:58 AM
Jules
David Finch
Hi All
From the information that I have I've updated my P4 listing for Basestation 10_04_2020 - See attached zip file.
P4-GIV, SUN removed.
P4-BFV, BSA, FJA, KBL, KGB, LNZ and PLG added.
Any additions or corrections welcome.
Hope of some use.
DF
Pipo
Can someone help me how i can ad all MIL in to the Countries.dat file?
When i see now a dutch mill plane it only shows the Dutch flag, not the roundle of the RNAF, I want to do this with all the MILL *bmp files that are located in BMPFlags folder.
Uniden UBC125XLT
David Finch
Hi Pipo
You need 2 things.  Firstly, a set of flags that have both the civil flag and the military roundel.  I got mine from:  http://woodair.net/SBS/Utilities/Kinetic_Utilities4_Bitmaps.htm  There are a few sets to choose from and you can pick the one you like best.  Alternatively I can send you the ones I have zipped up.
Secondly you will need an updated 'Countries.dat' file.  There is one on the web site above but that's way out of date.  This file is pretty much being continuously updated as information becomes available.  Again if it helps I'll gladly send you the one I'm currently using.
Hope that helps.
DF (29tiffie@gmail.com)
David Finch
Hi All
From the information that I have I've updated my P4 listing for Basestation 05_08_2020 - See attached zip file.
P4-AEG, BFF, GEM (Now RRR), KCF, PDE removed.
P4-CCC, HBK, RRR (Ex GEM), IKH and MCO added.
Hope of some use.
DF
Hi All,
Looking for some advice on modifying my countries.dat file.
I have recently seen a few Aeroflot aircraft showing the UK flag not the Bermuda one. Using Kelvin's (egnx) excellent spreadsheet confirms the hex codes will show the UK flag.
https://radarspotting.com/forum/index.php/topic,9361.msg40176.html#msg40176
Looking at my PlanePlotter list of hex to flag associations, it shows 424200 to 424AFF are allocated to Bermuda (may or may not be correct). The question is, how do I show a range (from / to) in my Conntiries.dat file? Or is it set up to find a match with a binary starting at one value and then it assumes all the following ones are in the same flag range until a change in binary code is reached?
My current Bermuda entries are as follows:
Any help / pointers gratefully received.
David Finch
The x in a line means anything, 0 to F
If you take a look at the first line in blocks of 4
                      4       0      0      0    the first hex that starts with 1 is 8 and the x's mean anything.
So that's 400080 to 40008F
Hope that helps.
DF
Hi Tim
My understanding is Countries.dat doesn't work on a range of codes, rather "batches" beginning "with" a defined number of characters:
https://radarspotting.com/forum/index.php/topic,7159.msg33736.html#msg33736
If PlanePlotter assigns hex 424200 to 424AFF to Bermuda, one could add this to the Countries.dat file:
BUT, this assumes there are no other hex codes beginning 424 allocated to another country.
Looking at my BaseStation Reporter, there appear to be Isle of Man registrations beginning 424 as well as some for the Cayman Islands.
From what I can find, the UK was allocated a range of hex codes by ICAO and has sub-allocated some of them.  But I can't find a definitive list!
Maybe trial and error?
Thanks for those replies. I need to try and get my head around the format. I'll try and complie a list based on DF's post.
Mike, I think there might need to be a zero at the front of your binary code?
David Finch
Hi Tim
I should have added that given the info re the blocks of 4, you should be able to work out the range of Hex codes that each line in your file covers.
Once you have that you should be able to see where the blocks need to be changed or added to accommodate the Aeroflot codes that are currently picking up the UK flag.
FYI I have 23 lines for Bermuda in my file, I'm not saying that's correct but it works for me.
Be aware that Bermuda / Cayman / Aruba are pretty much in a permanent state of change.
Hope that helps
DF
Quote from: Triple7 on October 26, 2020, 04:05:14 PM
Correct.  Using "bad" converters!
I've corrected my post.  Thanks for spotting it Tim.
Quote from: David Finch on October 26, 2020, 04:07:25 PM
Hope that helps
DF
You could save me a lot of work and head scratching if you could kindly share your Bermuda list.
David Finch
Hi Tim
And there was me thinking you were up for a challenge!!!
OK
Here's what I have for Bermuda.  Any corrections, updates or changes welcome.
DF
I think, historically, the Countries.dat file has been adapted to handle the "exceptions", hence Tim's seventeen variations for Bermuda!
Originally the UK allocation was:
This "batch" would have included the Bermuda and IoM sub-allocations.
Then, as these came to light, we have had variations, such as:
All using the same first 6 characters as the "generic" UK allocation:
010000
It can get quite messy.
