May 26, 2026, 12:01:37 AM
GNS 5890 on a Pi
Started by gcopter1, April 09, 2018, 04:40:29 AM
gcopter1
I have one laying around and was wondering if I could use it with an RPI3.
Maybe someone knows how to get the GNS5890 working on an RPi but it doesn't look like it does out-of-the-box:
Driver support for Windows XP/Vista/2000/7/8/10 and Android V4.0 and higher.
usable on Notebook, PC or tablet PC
supports Windows XP/Vista/2000/7/8/10
http://www.gns-gmbh.com/index.php?id=238&L=1
This link describes how to get it working to feed FR24:
https://forum.flightradar24.com/threads/7228-How-to-get-the-GNS-5890-ADS-B-Receiver-amp-Raspberry-Pi-working
It uses ADSBox as the interface to the dongle.
I have a microADSB dongle which is very similar to the GNS-5890. The files provided with each seem identical.
Instead of needing to compile ADSBox to receive the data, I thought modesmixer2 might work instead.
On a virtual PC running Ubuntu I tried (instead of the adsbox command):
./modesmixer2 --web 8092 --location xx.xx:yy.yy --inSerial /dev/ttyUSB0:115200
But I keep getting:
ERROR    inSerial(/dev/ttyUSB0:115200) error open Permission denied
I've tried:
changing permissions for the device: no success
running with sudo but get: ERROR    inSerial(/dev/ttyUSB0:115200) error open Inappropriate ioctl for device
At this point I'mout of ideas due to lack of knowledge about how hardware interacts with Linux: you might have more luck on a Raspberry Pi since that is what the instructions were intended for ;D
Or spend a few dollars on an RTL dongle and save time.
#3
I have not used microADSB dongle for a long time, but I think in Linux it creates a device (case sensitive): /dev/ttyACM0.
When receiver was connected to USB port you can check the name of the created device with the command: ls -la /dev/tty*.
/sergsero
Sergsero
Thanks - that worked.  8)
But seems hardly worth the effort. The message rate is low and so is the range compared to what I remember for a dongle in same location.
I'll do a comparison of a dongle and the microADSB using a better aerial and position.
