November 25, 2026, 11:37:24 PM
What exactly have Air Nav done, post ST launch, to fix known bugs?
Started by Sun Worshipper, June 20, 2012, 04:39:11 PM
Roadrunner
birdie
Quote from: Roadrunner on February 27, 2013, 10:00:40 AM
This attached message on the AN forum is interesting
http://www.airnavsystems.com/forum/index.php?topic=7522.0;topicseen
Now they are p**ing everyone off
Can I go there and Pi$$ them off again and get myself BANNED again ?
Not an official announcement but as close as we can get from Runway 31, who seems to be AirNav's mouthpiece on the forum.
Note the comment about "no additions or enhancements" and the response from another member "I m not suprised its taking a while to sort it all out".  Yes, all of 40 months and still counting!
"There are no additions or enhancements proposed, only bug fixes.
The thumbnail photo(s) of aircraft retrieved from the Airnav server are not always the same image(s) retrieved from the links in fields LK and LK2 in the aircraft table.
The Mangled Type Designator Bug - ICAO Aircraft Type field gets "..." or other incorrect data populated into the field.
Data (callsigns, altitudes, squawks, routes, etc) being assigned to the wrong aircraft.
The Serial Confusion Bug - Information about an aircraft displayed next to the aircraft photo is derived from the aircraft table using a lookup key of the registration (AR). Where a duplicate aircraft exists with the same registration this can result in the wrong information being displayed.  Lookup should be done using the ModeS Hex Code.
The 'Via' routes bug - Where the 'via' destination is shown as the final destination of a route, and the real final destination is not displayed.
The Flight Merging Bug - If you pick an aircraft up on separate days using the same flightnumber as it had on the last day you recieved it, then the starttime/endtime for that flight in mylog show as being the  full24/48/72hour period and the flight does not go into reporter.
Local alerts not working if aircraft previously on network.
Equatorial Black Hole bug - Aircraft disappear from the map in the zone between 2°N and 2°S.
Preference box needs to be resizable to cope on PCs using 125% font size, or small screen size.
The Diacritical mark bug - The fonts used next to the photo does not support diacritical marks. All diacritical marks in the Navdata corrupt when shown next to the photo.
If you sort the Network Flights list by Distance ascending, there's always 10-20 aircraft at the top of the list with Distance and Bearing BLANK. Even though they are listed with a valid Latitude/Longitude, and appear on the map.
When setting the range in the advanced filters with the lat & long settings, then saving as a .flv, filter extension file, works as it should, but after closing AirNav & restarting the program the range filter cannot be used because there appears to be a default setting of lat 39.75 long -105.00.
The Spurious Position Bug
The Aircraft in Limbo bug
The Magic Carpet Bug
Aircraft Sessions Extended - Flights are being logged, when the aircraft has timed out. Does not occur to all aircraft.
ADS-B Aircraft take a long time to appear in the 2D map after they are first received when you are activated for 3D (The 3 buttons are visible on the top right of the screen).
Admin Restriction - On Certain corp machines, networks, admin is not given to the user and hence, RadarBox cannot be run without admin rights."
http://www.airnavsystems.com/forum/index.php?topic=7615.msg91568#msg91568
With all the loyal supporters, including the unpaid database editors and beta testers, beginning to vent their undertsndable frustrations, AirNav trots out this pathetic and patronising garbage:
"We understand that some users and testers are frustrated because of the apparent lack of development.
Anyway work continues on our side on V404 and several other systems. More news to follow."
Now where have I read that before?
And Tarbat's frank and honest post exposes the true issue, one I've been suggesting for years.
RodBearden said "Perhaps if a few more testers had been involved, progress would have been better."
Rod, the number of testers isn't the problem.  I always provided fast turnaround on testing, with comprehensive feedback on faults found, things fixed, suggestions, etc.  I must have put in hundreds of hours to testing of AirNav products, both hardware and software.  Many hours spent testing a new version that didn't even deliver the fix it was meant to, and also broke something else that previously worked.
I've been a testing manager in the past (UAT, Regression, etc.), but nothing like testing AirNav products.  My experience of Airnav beta testing is endless frustration as you wait for the developer to become available again to work on something you gave feedback on weeks ago.
The solution isn't to have more testers.  The solution is more developers, or at least developers who have the time to work on the software rather than doing their other job.
AirNav doesn't have the resources to fix bugs let alone enhance RadarBox functionality.  Sales dried up years ago and network revenue disappeared as soon as the free tracking websites appeared on the scene.
Rather than face the music, AirNav has embarked on a futile attempt to change its business model by launching RadarBox24, too little and too late.  And in doing so has p*ssed off the very people it needs to share data.  When it realised the game was up it did a volte face and started recruiting non-RadarBox users to make up the numbers.
Come one you fellow RadarBox users, show AirNav we mean business.  Turn off your sharing for a couple of days.  This could be our one and only opportunity to make a stand.
http://www.airnavsystems.com/forum/index.php?topic=7615.msg91666#msg91666
birdie
Quote from: Anmer on April 13, 2013, 07:36:32 PM
Please insert your nick below - raise your hands and be counted !
1). Birdie already turn OFF his RadarBox
2).
3).
4).
5).
6).
7).
8).
Latest update in response to another, ex-updatater's post.
Notice how AirNav neatly side-stepped the question about resources.
My guess there's only two - Andre Brandao (when he's not flying for Euro Atlantic) and Akbar Sherwani (if he's still there?), supplemented with contract programmers as required.  Such as ShipTrax (sunk without trace) and RadarBox24, going the same way.  It will soon be 4 years since the last RadarBox Windows update and no bug fixes.
"Ok, at the risk of this thread getting forgotten about, which let's face it, is exactly what AirNav would like to see, SteveJ and myself discussed, very briefly, how many developers were on the AirNav roster.................
Does anyone know, or care to divulge, exactly what the set up is with AirNav in respect of resource?
During my time as an "updater", it was never made apparent just exactly what the backroom team (?) consisted of resource wise.
If there is a team of people beavering away in the background, exactly what are they doing? Most likely they'll be busy posting free boxes out to anyone who lives in an area not covered by the hundreds(??) who , like me, live in an area adequately covered for their "network" purposes, and who, unwittingly had to pay for the privilege of owning the hardware,and obtaining access to the network.............
I find it insulting"
AirNav's (insulting) response:
"Regarding all these points and again we fully understand all your concerns.
Regarding the network coverage: RB24.com and the RadarBox Windows client software Network are eactly the same. This means that the extensive network increase we had last month on RB24 also reflected on the network for the windows clients software. We've added 100 new H24 stations in the last 4 weeks.
Rgding the new version of the windows client software: it is still being developed at this time with, as reported earlier, most of the bug reports already corrected."
How often have we read that assurance?
http://www.airnavsystems.com/forum/index.php?topic=7615.msg92096#msg92096
The cat's out of the bag  8)
Many of us have long suspected the one and only RadarBox software "developer" is Andre Brandao, a first officer flying B767 for Euro Atlantic, the "day job".  We could be wrong but it may explain why it's taking nearly 4 years to fix a handful of software bugs.  RadarBox software development is the part-time job.
The last "official" announcement from AirNav on 18th March 2013:
Just a small update on our Windows Client software: development continues and we are still focusing on the server-client communications protocol. After this we will focus on the new bugs reported by the beta testers. We will keep you updated when we have more news.
http://www.airnavsystems.com/forum/index.php?topic=7206.msg90574#msg90574
Then, on 8th May 2013, Runway 31, AirNav's unofficial chief beta tester, forum moderator and PR executive, suggested things were progressing and a revised beta would be released "within the next week":
I am aware that 4.04 is being worked on as I type and I trust that the testers will receive the beta within the next week or so and thereafter the results will determine what happens next, whether it is made available for wider release or whether like the last one it is sent back for further work.  I expect it to be the former but time will tell.
http://www.airnavsystems.com/forum/index.php?topic=7615.msg92409#msg92409
Today, when asked for a progress report, this little exchange took place.  As someone else often says "You couldn't make it up":
Any new updates?
No news and I dont expect any for at least 3 weeks.
Any reason why 3 weeks?
Yes  because Dev is not available
You must be joking.......tell me you're joking.
Why should I be joking?
So AirNav's only developer is on holiday now.
Now there's me foolishly presuming "Dev" was meant to be a generic term to cover AirNavs development team, but it now appears to be a bloke called Dev.......
I just tried to get the train to work,but I was told the driver wasn't available for three weeks
Honestly,are we dealing with a one man band here?
Think I know the answer!
No Dev isnt Airnavs only developer but keeps Radarbox to himself.
He is not on holiday either but has other committments which require him to juggle his time and which at this time has taken him away from his development role.
Summer's coming and Euro Atlantic has lots of charter flying.  RadarBox development takes a back seat yet again.  Brandao's priorities, possibly:
- Fly the B767
- RadarBox24
- Checking bank balance
- Facebook
- Eat
- Sleep
- Social
- RadarBox software bug fixes
What a farce.
Sun Worshipper
QuoteAny reason why 3 weeks?
D'ya know, when I first read this, I thought it said Div.  Having read the whole post I'm now convinced it's meant to say Div with a vy on the end!
Just another post which re-enforces what we've been saying about Air Nav and Brandao over the years is TRUE.
Do you thing Runway 31 is another Brandao alias?
Quote from: Sun Worshipper on May 17, 2013, 09:55:22 AM
No I think he's genuine and does a lot for the RadarBox community.  But I think he's been "Brandaoed".
Without Runway 31 and the diminishing band of contributors, AirNav would have a real problem and Brandao's latest moneyspinner would be well and truly scuppered.
I hope he's paying them well?
Sun Worshipper
QuoteI hope he's paying them well?
No chance, more likely he has incriminating photos of them. ;)
Believe it or not, the most recent announcement from AirNav was on 18th March 2013:
"Just a small update on our Windows Client software: development continues and we are still focusing on the server-client communications protocol. After this we will focus on the new bugs reported by the beta testers. We will keep you updated when we have more news."
That was three months ago and not a word since.
No wonder Tarbat is venting his frustration.  In my opinion, we will never see a new release of RadarBox software.
"The list of bugs (in the PDF attachment):
http://www.airnavsystems.com/forum/index.php?topic=6532.msg73955#msg73955
http://www.airnavsystems.com/forum/index.php?action=dlattach;topic=6532.0;attach=10487
And status on these bugs a few months ago:
http://www.airnavsystems.com/forum/index.php?topic=7522.msg89996#msg89996
What's the current status on my beta testing feedback?  Or was the months of effort put in by me and others a complete waste of time and effort?  Or has priority shifted from fixing bugs to tightening up the comms encryption?"
http://www.airnavsystems.com/forum/index.php?topic=7206.msg93890#msg93890
In the absence of any response from AirNav, Tarbat has posed a further question:
Quote from: tarbat
Airnav, any chance of an answer?  When I left the beta early this year, it was almost ready for release in my opinion.
Quote from: Hawkeye
It's still happening regularly.
Are you running the latest v4.04 beta?  All the items I listed as tested were only fixed in the beta, which has never been released.
But still no reply from AirNav.
But, given an opportunity to promote RadarBox24, AirNav posts this drivel:
Because of RB24.com  we are significantly growing our network with over 300 permanent sharers (both non-RadarBox units) added in the last month. We are adding new units at a rate of 2-3 per day so expect the network to grow in the medium term.
As an example today we've processed the addition of new receivers in Algeria, Alaska, Guatemala, several US locations. Follow new additions at http://www.facebook.com/radarbox24
Further proof that AirNav has abandoned the RadarBox hardware and software and is 100% focussed on RadarBox24, underpinned by shared data from other receivers.
But strange that 5 weeks later, there doesn't seem to be a noticeable increase in traffic?
http://www.airnavsystems.com/forum/index.php?topic=7821.msg93946#msg93946
birdie
Quote from: Anmer on June 21, 2013, 08:56:26 AM
Hi AirNav,
How come there is not a single plane at WSSS in RadarBox24 ?
Compare that crowded airspace full of planes at WSSS in FR24 !
Pi$$ed me off and PERMANENTLY BANNED me from using your Forum ? !
This is what I did to my RadarBox - I packed it into the Box. Not even use it as a paper-weight !
Now you have to swallow your words - " others' are fed with unreliable data from unreliable hardware - whereas RadarBox " ... why are you now begging NON-RADAR BOX users to feed RadaBox24 ?
You harvest what you sow.
Light at the end of the tunnel?
Nearly 4 years since the last RadarBox software version was released, an update, of sorts, from AirNav:
"The 4.04 was part of a beta test so not a technical bug fix given out to customers as such.
Apologies for the lack of response as the email was passed on as we cannot give out the 4.04 from support. Hopefully we will have a version soon to release."
No development schedule, just "hope".
Much cheaper than employing programmers.
The last announcement was on 04 April 2013.
"Beta testing of the new Windows client software version is going on as the first version was released to some beta testers. We are now correcting the reported errors and we will be back with more information."
No wonder most of us don't trust AirNav.
http://www.airnavsystems.com/forum/index.php?topic=7809.msg94162#msg94162
