May 01, 2024, 10:54:57 PM
Where to find the correct ACARS frequenz
Started by Pipo, May 16, 2021, 07:03:31 PM
Pipo
Hi all,
Where are the correct ACARS freq to be find< i have found this web site https://www.sigidwiki.com/wiki/Aircraft_Communications_Addressing_and_Reporting_System_(ACARS) but i also found on google that Europe has more then the 4 on that webpage:
131.525 MHz   European Secondary
131.725 MHz   Europe Primary
131.850 MHz   New European Channel
But on google i also found:
European New 136.750
European Sec 136.900
And do i need to put all those freq in the Build-in radio or does the sbs-3 automatic scans the freq
SBS-1e & SBS-3 Raspberry Pi 3 & Pi 4
Uniden UBC125XLT
The SBS-3 radio receiver is NOT a scanner.  You have to manually set the required frequencies.
See page 72 of the BaseStation Reference Manual.
Pipo
Quote from: Anmer on May 16, 2021, 08:03:47 PM
Im getting write now the most acars from freq:
131.725
131.825
Those where in the reference manual, but what about the other freq are they stil in use?
Uniden UBC125XLT
mhm
These are the UK and European freqs
131.525
131.725
131.850
136.750
136.900
Colon Cancer Survivor for the Time Being
L10H
In the Netherlands I get most traffic on 131.825, slightly less on 131.725 and only a little bit on 131.525.
Nothing on mentioned 131.850, 136.750 and 136.900.
L10H
Pipo
Quote from: L10H on May 21, 2021, 06:28:14 PM
L10H
Thanks for the info, im here also getting more on 131.725 and 131.825. Do you know any tool to decode some acars info? Or is this impossible to decode?
Uniden UBC125XLT
