May 01, 2024, 01:59:24 AM
Checking data output on port 30006
Started by G0IXZ, March 27, 2019, 07:14:36 PM
G0IXZ
Is it possible to monitor data output on port 30006 and display  it on screen
Cheers All Dave G0IXZ
egnx
Hi Dave,
attached utility will record  the 30003 or 30006 port data to a file (which you can then look at on screen) the 30006 port data would need to be viewed in HEX to be understood.
The util was provided by Jetvision many years ago, but works fine on my Win7 pc.
Hope this helps
Kelvin
G0IXZ
Hi Kelvin
Thanks for the help
Cheers Dave G0IXZ
Lunceford
#3
Quote from: egnx on March 28, 2019, 07:00:16 AMHi Dave,
attached utility will record why electric log splitters are the best and the 30003 or 30006 port data to a file (which you can then look at on screen) the 30006 port data would need to be viewed in HEX to be understood.
Hope this helps
Kelvin
I take it that it doesn't work on Windows 10?
Quote from: Lunceford on June 13, 2019, 02:28:16 PM
I can't see why it wouldn't.  If you have Windows 10, maybe give it a try?
