Hello everyone,
I am an issue with not seeing Military flags that I've added to VRS I made sure I pointed to the right folder in the VRS settings box. I also have commercial flags that are working fine and same with silhouettes are working just fine but not the Military flags. For the editor I am using VRS editor plugin. Can someone help please?
- Jamie
To avoid going over the same ground, I've had a lengthy exchange of emails and personal messages with NE-KID. This has included a link to my Guide (https://radarspotting.com/forum/index.php?action=tpmod;dl=item17) on logos and silhouettes and suggesting a check on the BaseStation.sqb database to make sure the OperatorFlagCode field is suitably populated with a matching bmp file name.
My last message read as follows:
The Guide I wrote clearly explains how flags/logos work. If, having read it, you still don't understand I'm not sure how to help you further.
But I'll repeat the basic principles one more time.
For any logo to appear, such as United or a milltary one, the database OperatorFlagCode field must be populated with a record that matches a corresponding bmp file that's found in the appropriate folder, usually OperatorFlags.
It's as basic as that.
You need to view an aircraft record that displays a flag and one that doesn't. And see for yourself what's different.
Alternatively, ask the question on the VRS forum.
Maybe I've missed something?
This morning I did some tests with VRS, an application I don't normally use.
I added USNAVY_VQ7.bmp to my OperatorFlags folder and changed the OperatorFlagCode in the BaseStation.sqb file for a BAe Hawk to USNAVY_VQ7.
As can be seen from the attached screen capture, the new flag appears as expected, after refreshing the browser page. Changing it back to HAWK worked as expected too.
What basestation editor does everyone use? I'm not sure how to use VRS database editor
You could download the BaseStation Reporter (free) which will allow you to view the BaseStation.sqb file and edit records. Reporter is installed as part of the BaseStation CD installation.
http://www.kinetic.co.uk/basestationdownloads1.php
Or you can use SQLite Personal.
I sent you a link to the VRS database Plugin tutorial in a previous PM.
I have the SQLite program open what do I do next? I have slow learning disabilities so that is why I'm having a hard time understanding what to do I never done this before. I opened the Basestation.sqb file but not sure where to go from there.
Maybe you need to find something less complex than SQLite.
Let's see if other members can suggest something easier? But whatever you choose, it will need careful use.
I think I got it..All I would have to do is click on picture url 1? To add the airplane logo for the desired aircraft? Then once done what do I click on in the SQLite to save the database?
You need to add the bmp file name (Just the bit before the .bmp) to the OperatorFlagCode field. I've explained this previously.
So I don't have put anything in the picture url section area just the operator flag area only correct? Also once I have completed the adding the operator flags what do I do next? How do I save the file since I added the flags?
(https://i.ibb.co/TYfSRTT/Screenshot-25.png)
I'm not a regular user of either VRS or SQLite. SQLite may update the data fields on exiting that field. The database may be updated immediately and not need saving. I'm afraid I can't be more help.
No problem I appreciate the help Anmer. Just want to make sure I do not put anything the picture url area just the operator flag area correct?
Hope it's OK to jump in here.
First things first - before you edit your SQB file using SQLite Personal - back it up. SQLite is very powerful, and it updates your sqb file on the fly - so if you make an error you can destroy the file.
You only need to amend the OperatorFlagCode field – see screen grab attached and, as Anmer has previously stated, as long as you have a corresponding .bmp file in your OperatorFlags folder (or whatever it's called in VRS) with EXACTLY the same name, it will display that "flag" (logo).
Hope of use,
Thanks Tim.
Quote from: Triple7 on January 08, 2020, 05:25:40 PM
Hope of use,
Hello Tim,
Thank you for that helpful information. I' made a make up copy of the basestation.sqb which is a good thing. Does SQLite automatically saves the database once I complete editing the operator flags or do I need to do anything else before closing out the SQLite program?
Edit what I am seeing once I add the operator flag and it loads it as BM6 in the box?
The modifications are saved immediately, hence the suggestion to back-up!
You don't need to do anything other than make the edits you need.
Quote from: Triple7 on January 08, 2020, 05:33:55 PM
Thank you Tim for the help as well. Once I select the operator flag logo it saves it as BM6 is that right or no?
Now you have confused me!
Using SQLite you just enter the name of the bmp file (without the '.bmp' bit of course).
I'm not sure what you mean by "it" saves it as a BM6 - what is "it" and I don't know what a BM6 file is!
Quote from: Triple7 on January 08, 2020, 05:43:24 PM
The box located in the photograph below. I clicked on the operator name only it came on the screen as BM6
If you are clicking on the three dots to right of the cell, don't, just hit F2 to edit the field and type the filename.
Got it! Thank you so much for the help Tim. ;D
Pleasure 8)
Just an update so far no issues I got the operator flags working for Military aircraft! ;D ;D ;D ;D ;D ;D
That's good news.
Can you let us know what fixed it? Was it editing the sqb file and adding bmp name to the OperatorFlagCode field?
Quote from: Anmer on January 10, 2020, 08:30:10 AM
That's good news.
Hello Anmer,
What fixed it was me editing the basestation.sqb file in SQLite and only using the name in the OperatorFlagCode area. :)
Thanks. That's what I thought it would be but just wanted to be sure.
Quote from: Anmer on January 10, 2020, 12:46:09 PM
Always good to make sure. :)
